Sponsored by: Kumho
SKYJACKER 8"
Old Aug 6, 2002 | 11:15 PM
truckfreak69's Avatar
truckfreak69
SKYJACKER 8"
skyjacker makes an 8" lift for my 93 f-150, i was wondering if i can install this without doing any work to the driveshafts? If not, can i fit 36's with the 6 inch lift?
Old Aug 7, 2002 | 07:14 AM
MustangGT221's Avatar
MustangGT221
SKYJACKER 8"
You should be able to fit 36" with a 6" lift if you have a 4x4. What kind of configuration do you have? As in supercab, long box, short, what? Most likely you will need some lengthening of you're driveshaft. If you have sway bars, they will need to be lengthed with drop shafts. Brake lines are a must, new shocks, but you probably already know that. Thats about it.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 7, 2002 | 01:34 PM
bhredpowerstroke's Avatar
bhredpowerstroke
SKYJACKER 8"
