using 4x4
Old Nov 14, 2008 | 11:24 AM
puppy11's Avatar
puppy11
using 4x4
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>hello i'm new to the beast's 4x4. how do i use/or when do i use the 2x4, 4x4 switch, and or the hub lock. because i put the hub locks on once it felt like i was running over 4" curves when turning 2 to 5 mph
</TD></TR></TBODY></TABLE><!-- / message -->
<!-- controls --><TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>
<!-- controls -->
Old Nov 14, 2008 | 11:56 AM
Monsta's Avatar
Monsta
Sit. Stay.
There are hundreds of threads dealing with how/when to use the various functions on the ESOF 4WD system. However, I'll give you the Reader's Digest condensed version.
1. ESOF = Electronic Shift On the Fly
2. Switch to 4WD at any speed up to 55mph when travelling in a straight line. Flipping the switch electronically activates the transfer case and lock the hubs in via an vacuum pulse.
3. Use 2x4 most all the time.
4. Use 4LO in extreme circumstances such as deep snow/mud/rocks, pulling out stuck vehicles and such or when you need more grade braking. (not all situations)
5. Use the hub locks if the ESOF fails to lock your hubs, if you are stuck and cannot get enough rotation of the front wheels to lock (it takes 1/2- full revolution).
Don't use it on dry surfaces when attempting tight turns.
You should be able to lock the hubs w/o 4WD activated and NOT get the binding you experienced.
Old Nov 14, 2008 | 12:06 PM
puppy11's Avatar
puppy11
thank you very much
vloney
6.7L Power Stroke Diesel
Nov 2, 2013 09:56 PM
1950gmcelc
17
Jan 1, 2009 10:17 PM
donny3369
Dec 3, 2008 08:13 PM
Bowie
Nov 6, 2008 03:05 PM
