Timming Marks for '67 352?
Old Nov 14, 2008 | 09:16 AM
Rubidon's Avatar
Rubidon
Hello people,
A friend of mine is coming over tomorrow morning to use my garage to put a new timming belt on and we don't know how the timming marks need to go any help would be appreciated Sorry guys I forgot to mention it is a 1967 352 cid engine
Old Nov 14, 2008 | 01:36 PM
bertha66's Avatar
bertha66
Timing Belt? A 67 352 will have a timing clain and gears. There are marks on the gears and they line up together, cam gear pointing down and the crank pointing up.
Old Nov 14, 2008 | 03:17 PM
Rubidon's Avatar
Rubidon
Ya thats what I meant timing-chain,so the two marks have to point towards each other. Should the number one cylinder be at tdc on a certain stroke? Which one is #1 as sitting in drivers seat?
Old Nov 14, 2008 | 04:12 PM
Danger_Dave's Avatar
Danger_Dave
if standing in front of the truck the cylinder layout is:
4 8
3 7
2 6
1 5
so its on the passenger side closest to the bumper. i always pull the plug and place my thumb on the hole. when youre rotating the motor with a 15/16 socket you will feel it compress. that compression stroke is what you want to be tdc of. ready to go bang and fire the charge.
a friend helped me swap mine out and the difference afterwards is night and day. be sure to have a harmonic balancer or steering wheel puller handy because chances are its never been off, and it will sure be stuck after 40 years. you'll know when you find the plastic teeth on the stock gears that are chipped away and the loose as a goose chain.
Old Nov 14, 2008 | 04:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The harmonic balancer used on 1965/67 F100/350's w/352's is not the same as 1968/76's w/360/390's used.
Totally different design.
Look closely at that balancer, it may be defective.
Balancers are assembled from three different parts, outer pulley, inner damper, and...
Between those two parts is a rubber collar.
During assembly, the rubber collar is placed between those two parts, then the three parts are pressed together.
Over time, the rubber shrinks from age, cracks, then the outer pulley walks away from the inner damper.
When that occurs, a vibration results and if not replaced, the pulley can come completely apart from the damper and impact the radiator core.
The good news is, the 1965/67 balancer has been reproduced.
dearbornclassics.com / Online catalog / Page 158 / Dearborn's part number: HAB10.
