hey y'all, this is my 1st 68 ford so i don't know. but is my turn signal lever on my 68 f350 suppose to return to nutrual position after completing a turn,because mine does not.
yes it should...there is a part that breaks a fair amount i believe....dont ask me what part it is...Bill???? but i do believe it should my 69 and 70 both did/do.
thats what i thought, after driving Mack trucks their turn signal switch does not return either so you get used to it , but with my ford it doesn't opperate as smothly as the Mack, so returning it manually is not as convenent.
my flasher stoped working and i didnt replace it for a month or so and in that time i just got used to not using my trun signals....and now i still dont use them much.
i have to agree with bill, i replaced the cancelling cam in mine and was an absolute pain and did not last long. maybe a month..i finally ended up replacing the entire switch..i think it was around $60-80 bucks...been working good for for 4 years now.
mine doesnt self cancel, but i dont mind. i just put a loud flasher in there so i dont forget to shut it off myself. i mean you just click the friggin thing with your finger. talk about bein spoiled haha. its just like crank windows vs power windows ya know?
My turn signals work sometimes and sometimes not. I'll be driving down the road, use the turn signal and it works. 2 minutes later nothing flashes. If i pull the emergency ****, the turn signals light up and stay on but not flash. I replaced the flasher, but no luck. Sometimes it flashes, sometimes not.. Any ideas? My auto cancel doesn't work. But 90% of the time i ride my motorcycle so i am used to that! I'm just wanting to fix my turn signals.
There are TWO flashers behind the dash, both look identical.
One is for the Emergency Flashers, one for the turn signals.
Dave, Can't say if your flashers are dead or not, but they are inexpensive to replace.
I see dirt and corrosion as the culprit, clean your bulb sockets, check all wire connections, look for grunge in spliced trailer connectors etc. all places for dirt and crud to collect. IMHO
WHAT?!?!?!
I have got to check that out! Not that I don't believe you... actually, i have replaced my flasher with a LOUD flasher, and don't think I've ever used the emergency flasher **** on my truck. I will have to listen and see if it is noticeably quieter!
NumberDummy, you are an irreplaceable wealth of information. I would say you were a great person but I'm still convinced you are an advanced computer system, possibly the first beginnings of Artificial Intelligence. You're like half person, half machine.
