Troubleshooting fun
Old Nov 13, 2008 | 07:29 PM
ccg711's Avatar
ccg711
Troubleshooting fun
Greets to all,
For those that keep up, I got a compression gauge in today that has the right glow plug adapter and so far I've check 2 cylinders on my passenger bank, 3 & 5. 3 is just below 300psi and 5 is at a whopping 0psi (not a typo). Maybe this is linked to the loud BANG that happened as my engine bit the dust. comments?
PS I already bought a 2ton cherry picker and 1ton engine stand.
Chad
Old Nov 13, 2008 | 07:36 PM
Ponyboychris's Avatar
Ponyboychris
0 psi? You got a hole in your hole. Time to put the cherry picker to use. Sorry to hear.
Old Nov 13, 2008 | 07:40 PM
ccg711's Avatar
ccg711
yeah, with loud bank I'm beginning to think a piston gave way. Don't know why, it wasn't running that great to begin with. Anybody have any ideas, and how many threaten my re-use of the block?
Chad
Old Nov 13, 2008 | 07:43 PM
Ponyboychris
You won't know until the block is out and tore down. If you just punched a hole in the piston top, you may be OK but there might have been a lot of metal in the cylinder to score the you-know-what out of the walls. I have re-used old blocks (gassers) in the past for rebuilds after pistons let go and just bored them out.
Old Nov 13, 2008 | 08:13 PM
megawatt00's Avatar
megawatt00
Sorry to hear that. Like Chris said you'll know more when you tear her apart. Please keep us posted, and good luck to you.
Old Nov 13, 2008 | 08:37 PM
ccg711's Avatar
ccg711
#1=360PSI
#3=290PSI
#5=0PSI
#7=190PSI
Oh the fun.
Chad
Old Nov 13, 2008 | 11:14 PM
ccg711's Avatar
ccg711
#2=410PSI
#4=360PSI
#6=410PSI
#8=Cant get the plug out the hole.
Don't these things have aluminum pistons i seem to remember hearing. Mines an early 99 BTW. I'm just thinking out loud here, I wasn't doing anything but daily driving when it gave way, so I have this horrible suspension that if the motor was dusted, it may not be what caused this catastrophic failure. Maybe that bad injector that was in that hole was the culprit, it has a new one now. Oh well, I'll start tear down this weekend probably.
Chad
Old Nov 13, 2008 | 11:21 PM
4inchlovin's Avatar
4inchlovin
O psi and theres not a window in the motor... WOw
Old Nov 14, 2008 | 12:02 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Sorry to hear that. Keep us posted.
Old Nov 14, 2008 | 08:19 AM
Kwikkordead's Avatar
Kwikkordead
Subscribing.
Old Nov 14, 2008 | 09:37 AM
Ponyboychris
Originally Posted by ccg711
#1=360PSI
#3=290PSI
#5=0PSI
#7=190PSI
Oh the fun.
Chad
190 psi on #7 doesn't look good either. Yes, they are aluminum pistons but if someone ran the motor nice and hot (high EGT's) it could have weaken the piston metal and created a soft spot to break. You probably got some garbage in the pan as well.
