Sponsored by: Kumho
Sway bars
Old Jul 2, 2002 | 03:20 PM
bigredtruck's Avatar
bigredtruck
Sway bars
Who offers front and rear sway bars for a 77F150 4X4?
I've seen them in JC Whitney. I'm just curious as to how good or bad these are, and if there is a better quality or more notable name making them.
Old Jul 3, 2002 | 09:45 AM
beartracks's Avatar
beartracks
Sway bars
JC Whitney still sells Hellwig I believe and those bars are killer.
Old Jul 3, 2002 | 11:11 AM
StrangeRanger's Avatar
StrangeRanger
Sway bars
check www.addco.net
Old Jul 3, 2002 | 11:06 PM
briefly's Avatar
briefly
Sway bars
[updated:LAST EDITED ON 04-Jul-02 AT 00:08 AM (EST)]
It might be worth noting here that if you are adding a front anti-sway bar to a SD, ('99 and later), which came with no anti-sway bar you had best check first to ensure you have the proper front end hardware to mount it. Hellwig supplies only the bar, a bushing, and a note which states their product is designed to REPLACE the factory bar using the factory hardware.
The rear bar from Hellwig is complete with a big plastic bag full of erector set type stuff to confuse poor fools like me, although I did get it installed to the amazement of my pal the mechanic).
If that doesn't fog things up enough, Ford doesn't even call the durn thing an anti-sway bar but a "stabilizer bar". This no doubt because the lawyers in Dearborn deny Fords have ever swayed. (I do too, but only to people driving Dodges)
Old Aug 12, 2002 | 12:45 PM
laptopgeek's Avatar
laptopgeek
Sway bars
Big Red Truck ----
Here are some pix I took this weekend....http://www.beedzncomputers.com/truck/suspension/front/front.html
Hoping this helps,
Old Aug 12, 2002 | 04:31 PM
smithy's Avatar
smithy
Sway bars
