Blower stuck on defrost.
Old Nov 13, 2008 | 06:44 PM
brittfan's Avatar
brittfan
I tried to do a search for this but got information overload.
My 2002 explorer is stuck on defrost. It doesn't matter where the dial is.
Recently, I found some acorns in the blower and got them out, but since then
it's stuck on defrost. What did I screw up?????
Old Nov 13, 2008 | 07:42 PM
danr1's Avatar
danr1
Defrost is the "default" setting, if vacuum is lost it will automatically go to the defrost setting to be sure the driver will be able to clear the windows.
I'd check and make sure you didn't knock the vacuum supply line off.
Old Nov 14, 2008 | 09:48 AM
Buck 1's Avatar
Buck 1
I'm with danr1; you have accidentally knocked the vacuum supply line off when you removed the acorns. Simple to fix.......find the line and replace it back on the nipple.
Old Nov 17, 2008 | 08:35 PM
brittfan's Avatar
brittfan
Thanks for the replies.
Seems like Mr. Gumby pinched the vacuum line.
All fixed.
cliffhanger_18
18
Nov 3, 2014 06:54 PM
Crabby144
1997 - 2003 F150
Oct 21, 2014 07:41 PM
kalam2
1983 - 2012 Ranger & B-Series
Mar 1, 2014 09:15 PM
SlickWiSlick
16
Nov 5, 2009 07:10 AM
