Thermostat O-ring Replacement?
Old Nov 13, 2008 | 05:32 PM
nlemerise's Avatar
nlemerise
As luck would have it, after changing the coolant over to Delo ELC, the o-ring at the thermostat housing (I have the billet thermostat housing from DieselSite) has decided to give up the ghost...a small, but steady leak. Does anyone know where to get the o-ring to replace it (or have a spare until I can find one)? Went by the IH dealer after work this morning and they have it as a kit with the thermostat, not sold separately.
Old Nov 13, 2008 | 05:43 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
You're going to choke me. I threw a used, but still in good shape, one away this morning. The trash man came and took it all away.
I will run some internet searches and see if I can find one.
Old Nov 13, 2008 | 05:49 PM
Texas Outlaw
Not a liberal...
Neil, I think this is what you need:
Powerstrokeshop.com
Old Nov 13, 2008 | 05:51 PM
aklim's Avatar
aklim
Ford Dealer?
Old Nov 13, 2008 | 05:53 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Neal. I just finished that same problem. My new Billet housing started leaking. I finally fixed it by using Hi-Heat gasket maker. Use plenty of it and tighten down the two bolts between the leakiing area first. Took me 2 times taking the housing off to finally get it fixed. I think the trick is to tightening the bolts in the right order. Not a drop now.
I also used the same gasket on the stat.
Old Nov 13, 2008 | 06:11 PM
SpringerPop's Avatar
SpringerPop
First, everything has to be CLEAN! Then, I use a very light coating of Permatex Aviation Form-a-Gasket on both surfaces.
The trick is to set everything in place, thermostat, gasket and housing. Then, while evenly pushing down on the top of the housing, start each bolt by hand and run them down until the head each just touches the housing. At this point you know that the pump's surface is still parallel to the housing's surface.
Then, just turn each bolt one third of a turn at a time until the housing is tightened. You've taken the housing down evenly, which is the trick.
Never a leak. First time, every time.
Pop
Old Nov 13, 2008 | 06:59 PM
nlemerise's Avatar
nlemerise
Pop
I took it apart this afternoon and recleaned everything...Clux has graciously offered to send me a gasket and I will also use the Permatex on the housing. Thanks Scott for the link, but to get them to send one costs $13.00 in total ($3+ for the gasket and $10 for shipping). Good Lord!!! Thank you guys for your help...
Old Nov 13, 2008 | 07:12 PM
SpringerPop
He be the MAN for o-rings!
Pop
Old Nov 13, 2008 | 07:28 PM
Smokin''s Avatar
Smokin'
Smokin
I have an extra thermo o-ring (brand new) in case anyone else ever needs one.
Old Nov 13, 2008 | 07:47 PM
jtharvey's Avatar
jtharvey
I bought one, just the o-ring, at orielly's a couple years ago. One other thing I do is to coat the o-ring with some silicon grease. I picked up a small, quarter sized container of it at Lowe's, in the plumbing department. It's used to lubricate the o-rings on faucets. Coating the thermostat o-ring will allow it to squeeze into the proper place without being crushed or pinched.
Using the silicon grease and the tip that Pop provided, I've not had a leak on thermostats I've done since then.
Old Nov 14, 2008 | 01:37 PM
Supercab's Avatar
Supercab
Wink
I didn't realize that these "O" rings were so hard to come by....I had changed my T-stat & installed the billet housing under a year ago, then water pump went, and I tried re-using the "O" ring with everything new and very clean and got a leak, so I went to Autozone & got a new "O" ring for about $4.00 they had plenty in stock!! no leaks!!
Old Nov 14, 2008 | 02:56 PM
CampSpringsJohn's Avatar
CampSpringsJohn
I recently replaced the thermostat in my 97 with a motorcraft thermostat. It was different than the old one in that the rubber o-ring wrapped around the outside edge of the thermostat. It was a part of the thermostat. Much better design that the original. Using that, along with Pop's technique in tightening the bolts, you should be good to go. I did use permatex on the housing when I changed mine too. No leaks.
CB3
Sep 3, 2016 06:12 PM
smallello
May 7, 2016 09:31 PM
AremRed
Escape & Escape Hybrid
Jun 8, 2015 07:54 PM
hodge5
1983 - 2012 Ranger & B-Series
Sep 18, 2014 03:46 PM
northwindone
Modular V10 (6.8l)
Mar 12, 2013 10:05 AM
