Sponsored by: Kumho
radius arm bushings
Old Apr 30, 2002 | 07:59 AM
TallPaul's Avatar
TallPaul
radius arm bushings
Old Aug 12, 2002 | 10:42 PM
4x4's Avatar
4x4
radius arm bushings
I have a 95 F150 4x4 and I'm going to replace the radius arm bushings. I noticed on the passenger side that the bracket for the radius arm bushings has bolts in it, and the drivers side has 2 bolts and 2 rivets. I'm assuming that somebody has been in the passenger side already. Can the bushings be replaced by just removing these bolts and grinding the rivits off? Is there enough room to get the bracket off so the front part of the bushings can be removed? Also, any tips on removing the rear nut on the radius arm?
Thanks for any advice.
Old Aug 13, 2002 | 08:51 AM
marriedguy1's Avatar
marriedguy1
radius arm bushings
Loosen the big nut with everything still attached to the frame, but do not remove it completely yet. Yeah grind/drill out the rivets on the driver's side and replace with new grade 8 hardware. On my Bronco there was plenty of room to remove the bracket and get to the front bushing. It sounds like you have a good handle on what this job is going to take so go for it.
