Axle Issues
Old Nov 13, 2008 | 09:17 AM
Black Smoke '88's Avatar
Black Smoke '88
Axle Issues
I have an '88 F250 4X4 with the 7.3l non-turbo diesel. I don't know exactly howbut ji managed to break the passenger side front axle shaft off inside the pumkin. I have pulled it all apart and cleaned everything up but I cannot find a new or used axle. This truck has the Dana 60 front axle and no one seems to have the part I need. Can anyone help me locate an axle?
Old Nov 13, 2008 | 07:01 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Black Smoke '88,
Welcome to FTE and the IDI diesel forum.
The 250 should have either a Dana 44 or Dana 50 IFS front axle.
Regular cab is usually a 44, extended or crew cab is usually a 50.
Are you sure it is a 60 monobeam axle?
Here is a passenger side Dana 60 axle at Summit Racing.
Superior Axle and Gear PA6385B - Superior Axle and Gear Evolution Series Front Axle Shafts - summitracing.com
Old Nov 14, 2008 | 04:37 AM
Dodge/Cummins's Avatar
Dodge/Cummins
Do you know how to tell one from the other?
If you don't it's really easy for one of us to tell you how to identify it.
I'm asuming since you even know about a Dana 60 you can.
It's your first post so were not sure how "advanced" your knowledge is.
And we don't care, if your new to trucks don't worry about asking "dumb" questions.
Old Nov 14, 2008 | 08:22 PM
Dave Sponaugle
Here are links to the three most common axles Ford used from the Dana Librarian.
Full info on identification and servicing the axles in .pdf files.
You need Acrobat Reader to open them though, Acrobat Reader can be downloaded for free if you don't have it on your computer.
Dana 44 IFS
Dana 50 IFS
Dana 60
Old Nov 27, 2008 | 12:54 PM
Black Smoke '88
You were right and i was a little confused...my truck has the 50...i was also wondering if it is worth the time money and effort to convert it to a live axle. also if i am going to go that route, what is needed to do that kind of a job, not tools but parts.
Old Nov 27, 2008 | 04:22 PM
Dodge/Cummins
If you get your axle with the track-bar and bracket attatched it'll bolt right in.
IMO it would be one of the best upgrades you could do.
I don't know how much money or time you have but the cheapest way to get a Dana 60 is to buy a whole donor F-350 and swap everything then sell the donor F-350 with your Dana 50 in it instead.
Take a quick look under the DONOR before you buy it and make SURE it has a Dana 60 in it.
Old Nov 27, 2008 | 06:20 PM
Dave Sponaugle
Going 60 price here is 1500 dollars, if you can find one.
Old Nov 27, 2008 | 09:20 PM
Dodge/Cummins
I've seen them sit on Craig's List here for 700 bucks but I'm SURE it's a regional thing. 1500 seems to be the "national" average.
If you buy an F-350 right, swap everything and resell the truck you might get it for free. Or close to it.
Old Nov 29, 2008 | 01:47 PM
Black Smoke '88
awesome! thanks guys...i found a guy that i work with that has an 88 f-250 4x4 with the 4 doors. he has a rear axle, a front live axle, and a 6" lift kit with all the parts needed, but the shocks are shot (no big deal) and i am gonna buy the works this week for $300. i think that 2 dana 60s and lift for that price is a great deal. Thanks again for all the help!
Old Nov 29, 2008 | 02:58 PM
Dodge/Cummins
BE CAREFULL!
An '88 4-door (CrewCab) should be an F-350 (1-Ton) so make sure you're getting what you think you are.
If everything is right that's a KILLER deal!
Old Nov 29, 2008 | 03:29 PM
starmilt's Avatar
starmilt
More like a steal
Old Nov 29, 2008 | 06:57 PM
Dave Sponaugle
If the 88 is a diesel it should have a Sterling in the rear.
If it is a 250 the front is a Dana 50 IFS unless someone has changed it.
Old Nov 29, 2008 | 10:04 PM
starmilt's Avatar
starmilt
What exactly is a live axle.
Old Nov 29, 2008 | 10:45 PM
goodB0Y's Avatar
goodB0Y
I've never heard that term either... 1800 bucks is the going rate for a D60 waaaay up here in canada... got mine for 1500 and the rest of the truck with it...
Old Nov 29, 2008 | 11:15 PM
Dodge/Cummins
Live axle is just another term for a straight axle.
