Offroad & 4x4
Bigger Tires Speedo Correction?
Old Nov 12, 2008 | 09:50 PM
Prozon's Avatar
Prozon
So with my 37's my Speedometer is about 10mph off.
I used the search button to read about it and it seems I need different teeth on my speedo cable? I'm totally clueless. How much does it cost to correct my speedometer or how could I do it myself?
And if anyone can tell me if I can get a gauge cluster to fit my truck (88 F-350) with another mileage digit so that it doesn't roll over at 100k. And a price for this?
Just thought i'd ask in the Off-Road forum because you all have probably had this issue upgrading tires.
And until then I suppose i'll just go 10mph under the speed limit, but I would like to correct this.
Stock Tires - 265x75x16
Current Tires - 37x12.5x16
Any help is appriciated. Thanks.
Old Nov 13, 2008 | 07:31 PM
Prozon's Avatar
Prozon
Where is a speedo gear located? Thats what i've been hearing but I dont know anything about speedo gears lol.
Old Nov 13, 2008 | 08:14 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
with the sterling in the rear, the vss is in the rear axle....
Your truck have a computer? If so then i know how you can correct it for free... I will have to dig up the link though....
Old Nov 14, 2008 | 01:02 AM
75F350's Avatar
75F350
Change the gear ratio in the diffs, and you will once again have a speedo that reads correctly.
Old Nov 14, 2008 | 07:13 PM
Truckin4life
You sir are correct!
Old Nov 15, 2008 | 09:23 PM
Prozon's Avatar
Prozon
I'm probably going to end up re-gearing but not for awhile. The 37's are pretty nice with 4.10's. It would probably suck if I had overdrive, but its just a three speed and it seems to even things out.
jlmotox
Jul 19, 2014 12:54 AM
Medicman78
Jan 21, 2014 01:42 AM
reaper75032
Dec 28, 2012 12:28 PM
billsimcox
1997 - 2003 F150
16
Mar 10, 2006 08:47 PM
