gear ratio question
Old Nov 12, 2008 | 07:37 PM
Chucky Babe's Avatar
Chucky Babe
Question gear ratio question
how do i tell what gears i have in my axle
Old Nov 12, 2008 | 09:27 PM
Conanski's Avatar
Conanski
Look at the decal on the drivers door pillar and find the axle code... https://www.ford-trucks.com/article/...de_Chart_.html
Old Nov 13, 2008 | 02:46 AM
Chucky Babe
Thank for your help
UTfball68 i like your signature
Old Nov 13, 2008 | 05:34 AM
TexasGuy001's Avatar
TexasGuy001
You can also jack up the rear of the truck and rotate the tire and count how many times the driveshaft rotates for one wheel rotation.
IE If the wheel rotates once and the driveshaft rotates 3 and a half times you probably have 3.55 gears. If it rotates about 3 times you probably have 3.08 gears.
