New noise
Old Nov 12, 2008 | 11:12 AM
CanadianSmokie's Avatar
CanadianSmokie
New noise
The trucks getting new ball joints on the drivers side next week but I noticed a intermittent hum /growl when driving in a straight line that increases in frequency when speed increases. Could this be related to the tight, squeaky ball joint? Or is this what a bad wheel bearing sounds like. I difinitely sounds like its coming the front left but you know how noises are.
FWIW, I started noticing the noise after I replaced the rear pads.... doesn't seems like it could be from that but who knows....anyone have any experience with anything like this?
Thanx...
Old Nov 12, 2008 | 12:27 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Funny story, I noticed the same thing.....
What is that?!?
Old Nov 12, 2008 | 07:03 PM
CanadianSmokie
I think I'll take the rear wheel off and see if the pads are retracting properly. I just got the local shop to throw a set of pads on the rear to pass safety until I get around to replacing them with something better. Possibly the slide pins weren't cleaned and lubed....
Old Nov 12, 2008 | 07:16 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Ken,
Very likely tied to the rear pads...but by chance have you engaged 4 wheel drive recently? I ask because last winter when I engaged mine and disengaged it one hub I suspect did not completely unlock. As I drove...I had the sound you described...I ended up re-engaging 4 wheel drive...driving a little bit...disengaging it while rolling forward...then stopped and backed up about 20' (an old trick I used to have to do with my 92 Exploders hubs)...it seemed to clear the sound and the other times I engaged 4 wheel last winter it did not repeat itself...Just a thought...but again...you may have the E brake needing adjustment or a slide pin needing lubed as you suspect.
Good luck...keep us informed.
Joe.
Old Nov 12, 2008 | 09:46 PM
UrbanXX's Avatar
UrbanXX
My friend has an Avalanche that had this same kind of weird noise. He replaced both front pads, one rotor, and a caliper. Did not help one bit.
I looked on the internet for this problem and here is what I found.
These trucks have very small shoes inside the hub of the rear rotors for the emergency brake. These were viberating due to dust and rust sending the noise down the emergency brake cable to the cowl section of the truck. This is a common problem on some of these trucks.
So taking this into account, I would suspect you noise is comming from the rear brakes and the noise is being sent down to the front via the emergency brake cable.
You may get someone with a little knowledge ride in the second row seat with the window down to verfiy the fact if noise is comming from the rear.
03 Limited V-10
4X4 Black
Bone Stock
Keepen it real
