Getting close!!
93 Bronco 5.8 automatic going into a 92 f150 5.0 5 speed
So now that I finally have the tranny identified ( AODE/4R70W go from 92 to present. It’s pan is similar to the AOD. These trannies have a large neutral switch (sometimes called a MLPS) mounted to the manual linkage and has a hole covered by a rubber plug on the bellhousing’s bottom. 4x4 truck pans (and 76+ model cars and 2wd trucks) are dropped near the center) Now being that there are no electrical connections on the tranny, should/will the wiring harness plug right into the existing computer and work??? Thanks Scott
