timing question 4.9?
Old Nov 11, 2008 | 11:07 PM
9.ford.5's Avatar
9.ford.5
ok first off does anyone know factory timing settings on a 95 300I6 EFI? i went and had it adjusted today and it was between 6 and 8 somewhere i couldnt see the nubmers due to mud shoulda cleaned it off and tried again but whatever...so anyways i set it up at 10 does anyone run this or any other setting other than stock and hows it compare to stock
thanks ya
Old Nov 12, 2008 | 01:33 AM
red bud's Avatar
red bud
10 btdc is stock, some people and myself, has have good luck running 12 btdc. Gives it a little more bottom end.
Old Nov 12, 2008 | 10:51 AM
9.ford.5's Avatar
9.ford.5
ok what does btdc stand for again i think i know but im not sure ha...well ill see if i can get my bud with a timing light and set er up thanks man...did you notice better mpg when you did that...thats pretty much why im setting it
