engine replacement
Old Nov 11, 2008 | 06:16 PM
lunderwood's Avatar
lunderwood
engine replacement
will a 1997 ranger 2.3 engine run correctly in a 2001 ranger 2.3 or is the sensors/computer different ?
Old Nov 11, 2008 | 08:42 PM
michigan66's Avatar
michigan66
If the engine in your 2001 is the DOHC 2.3 Duratec engine (143 CID), you are dealing with two different engines. The 2.3 SOHC Lima engine (140 CID) is a completely different engine family. Early 2001 models had the 2.5 SOHC Lima engine and may make a swap. I'm not sure about emission systems which would result in different sensors compared to the 1997 2.3.
Old Nov 12, 2008 | 07:18 AM
wendell borror's Avatar
wendell borror
The computer, harness and sensors would all be different on the 2.3 dohc duratec.
Old Nov 12, 2008 | 02:29 PM
80F100man's Avatar
80F100man
How hard would it be to install a 2.7L V-6 twin-turbo diesel in place of a gas engine?
stimanviii
Jun 26, 2008 10:27 PM
JakeFM
Jun 9, 2005 01:20 AM
Great Parts
4 Cylinder Engines
Jan 28, 2005 08:57 AM
TallPaul
4 Cylinder Engines
Oct 6, 2002 04:59 AM
