Sponsored by: Real Truck
Heated Seat Problem
Old Nov 11, 2008 | 05:25 PM
mvcrete's Avatar
mvcrete
Heated Seat Problem
When I Press The Button For The Drivers Side Seat, The Light Turns On For A Second And Then Turns Back Off. Any Clue???
Old Nov 11, 2008 | 11:12 PM
patrickke's Avatar
patrickke
bad wire/button connection? or maybe the heater has gone out or maybe even there is a short...too many possibilities too little time lol
Old Nov 22, 2008 | 09:38 PM
mvcrete's Avatar
mvcrete
checked the passenger side today and it worked fine. it's gettin' cold out !
Old Nov 22, 2008 | 09:43 PM
hughjazz's Avatar
hughjazz
you could always sit on your purse,,,or your shawl... lol just kidding.
Old Nov 22, 2008 | 10:51 PM
dstig1's Avatar
dstig1
I assume that the seat heater is not working - that means no heat - ??? It could just be the light has a loose connection.
Otherwise: You're going to have to trace it. See where the power is lost in the circuit. Yes, it's a PITA, but there isn't much else you can do. If the light comes on, then the fuse is good, so your problem is somewhere else. Check grounds, check for voltage starting from the seat or from the fuse panel, and work your way through it.
-Dave
Old Nov 24, 2008 | 03:20 PM
rmosso1's Avatar
rmosso1
KISS answer is this.
Does the seat get warm after five minutes?
Old Nov 24, 2008 | 09:42 PM
mvcrete's Avatar
mvcrete
Cool
no. it doesn't get warm at all. all the rest of the power seat works fine. as i said earlier in the post. press the button , the LED comes on for a second then goes right off. passenger works fine. what the $#%&*!!!!
