Backseat noise
Old Nov 11, 2008 | 02:25 PM
Frdtrtnv8's Avatar
Frdtrtnv8
Backseat noise
I have an 08 xcab f-150. There is an annoying noise coming from the back somewhere, it is either the rear window, or the seat. My 05 f-150 made the same exact noise. It isnt a rattle, just like something is rubbing maybe, i dont know but its annoying. Has anyone else had this noise, what was it, and what did you do to stop it.
Old Nov 11, 2008 | 03:17 PM
JoSHN's Avatar
JoSHN
The best thing I can think of, is have someone sit in the back and listen as close as they can to pinpoint the sound. Then, once you've figured out where it's coming from, you can solve the problem from there.
Otherwise, with a lack of description, it could be anything.
Unless someone has already had the issue and knows exactly what you're talking about.
Old Nov 11, 2008 | 03:30 PM
sammer4u's Avatar
sammer4u
My 06 SCAB did/does this annoying noise. I have found it to be the seat beat buckles on the doors... I have to tuck them inbetween the door and seats to make them to stop making the noise. I notice it when somone is in the back and moves the belts, or them get moved by putting stuff back there. It was very bad, and by tucking them in the seat and door it is not making the noise! I hope that helps you out somewhat!
Old Nov 11, 2008 | 04:48 PM
fitz888's Avatar
fitz888
Could be the jack under the seat
Old Nov 11, 2008 | 04:50 PM
fitz888's Avatar
fitz888
could be the jack
Old Nov 11, 2008 | 07:08 PM
tonythec's Avatar
tonythec
back seat noise
mine is the leaf springs. if it is worse backing out, when you change from driveway to street, yours is likely the same.
Old Nov 11, 2008 | 08:42 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
x2
does the same thing with my Screw. I just buckle the outside 2 belts if/when it annoys me enough
