Bolt tightening pattern for 390 intake?
Old Nov 11, 2008 | 12:55 PM
Payner44's Avatar
Payner44
Can someone tell me the tightening pattern for a 390 intake manifold? I believe the correct torque is 35lbs. TIA!
Old Nov 11, 2008 | 02:01 PM
Bear 45/70's Avatar
Bear 45/70
Start with a center bolt and spiral out toward the ends.
Old Nov 12, 2008 | 11:58 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
My Motor's shows (looking from the front)
5-4
10-7
1-2
8-9
3-6
I would, however, do it in three steps incrementing the torque a little each time.
Bear, I wonder, any way the difference in techniques might contribute or lessen intake gasket failure? (as in, your method being better)
Old Nov 12, 2008 | 12:27 PM
Bear 45/70's Avatar
Bear 45/70
5-4
10-7
1-2
8-9
3-6
I've seen both methods suggested. Seeing as how I've never had an intake gasket failure (other than end corks, which I don't count), no I don't see one as better than another. However the heads use the spiral method so I tend to prefer that.
Old Nov 12, 2008 | 08:16 PM
Barry_R's Avatar
Barry_R
Most important thing is temporarily stabbing the distributor in before any bolts - just as a locating tool. Next is to start all the bolts before tightening any of them. I usually check for intake flange alignment to the heads and port alignment before putting things together "for keeps". I tend to think that the FE intake is so large and so flexible that either pattern will work.
Old Nov 12, 2008 | 10:26 PM
jameslynch03's Avatar
jameslynch03
go geter, eather will work just do little at a time.
Old Nov 13, 2008 | 12:39 PM
krewat's Avatar
krewat
Barry, good point about the dizzy.
Old Nov 15, 2008 | 09:40 AM
Payner44's Avatar
Payner44
Guys, thanks for all the feedback. I asked the question because I am suddenly getting oil in my anti-freeze and figured the intake manifold may simply need tightening, since it's only got 15k on it since installation. I discovered that 6 of the 10 bolts took about an 1/8th turn to seat again. However, after flushing the system the problem still exists. Other than this issue the engine runs just fine with no other symptoms of trouble, and anti-freeze is not getting into the oil. So, I suspect all it needs is new manifold gaskets to solve the problem and not a head gasket...would you agree??
Old Nov 15, 2008 | 10:04 AM
Hypoid's Avatar
Hypoid
I'm gonna say no to the gasket question. There is no pressurized oil at the intake to push it's way into the cooling system. Off with the heads!
I hope it is a gasket leaking because of under tighteneing. Anything after that gets expensive.
Old Nov 15, 2008 | 10:45 AM
Payner44's Avatar
Payner44
So, try tightening the head bolts first??
Old Nov 15, 2008 | 10:46 AM
Hypoid's Avatar
Hypoid
Sounds like it's worth a try.
Old Nov 15, 2008 | 10:52 AM
Tyqmonn's Avatar
Tyqmonn
I hate to rain on you're parade But..... It sounds like the oil passages in the block have either rusted thru or have cracked. Very very common on FEs. You'll get oil it the coolant but won't get coolant in the oil. There is a fix for this problem. It's not too difficult.
Payner44's Avatar
Payner44
What is the recommended torque for the heads? Thanks!
Old Nov 15, 2008 | 10:54 AM
Payner44's Avatar
Payner44
And what would that fix be?
Old Nov 15, 2008 | 11:12 AM
Hypoid's Avatar
Hypoid
80 to 90 ft-lbs, starting at the center like Bear said.
The cracked oil passage fix is a hollow pushrod and JB-Weld in the block's oil passage.
