I don't see any reason why not. There's a guy I know around here that has a 78 F-150 w/ a 9" sus. lift and bushwacker cut out's and he has plenty of room for the 42" Swampers he runs. I have a 76 highboy w/ 3-4" of lift and cut fenders and I have plenty of room for 38's and maybe 40's. I guess it would depend mostly on the year of the truck but, I can't think of a Ford 1ton that couldn't fit 38"+ w/ 9" of lift and fender trimming. Heck, an old highboy w/ that much would be towering over 44's!
Lee, you shouldn't have any problem. I usually clear 38s with 8" kits so with cut-outs you won't have any problem. You may however need to shim your front bumper forward a bit depending on what brand tire and how wide a wheel.
__________________________
Overkill, 2000 X 4x4 Limited,V10, Black Monochrome, The Edge 12.5" Lift, The Edge Adjustable Track Bar, The Edge Monster Truck Traction Bars, The Edge Dual Shock Hoops, Bilstein 7100 Shocks (Custom Valved), ORU 7100 Dress-up Kits, ORU CrossOver Steering & Hydraulic Assist, High Angle Drivelines, 18/39-16.5 M/T Baja Belteds, 16.5x14 Weld Mountain Crushers, Crystal Head Lights & Corners, Trenz Billet Grill, ORI PreRunner Bar, Hella 3000s, Billet Fuel Door, Kodiak Power Steps (4), Con-Fer Dif Covers, Go Rhino Trusses, 5.13 Gears, Superchip, Borla Exhaust, Volant Filter, BBK TB Spacer, Custom Dark Graphite Carpet & Headliner, Custom Black Leather Seats, Custom Molded Carbon Fiber Interior Trim, Trenz Billet Door Sills, Weathertech Mats & Liner, Eclipse 7301 Multi-Media, McIntosh MC4000M, Focal Utopia 165W3 (2), Illusion Audio nd12 (4), Stinger Caps & Wires, Q-Logic Kicks, Custom False Spare Tire/Sub Enclosure
i"m running 39 inch gound hawgs with just 4 inches of body lift on my 79 f-150 4x4.. no problems at all....other than a rough noisey ride..lol.. but it looks like a total chevy cruncher...
ford boy you have 39 inch tires and a 4 inch lift do you have cuts on that f150.im trying to figure out what size to to run on my 78 f 250 i have a 4 inch skyjacker suspension lift on mine i have 33's on it now has lots of clearance i dont want to put a body lift or cut fenders if i dont have to bad 78 f 250
hey bad 78.. no i did"ent have to cut the wheel wells, i have about 3 inches of clearence and i"ve never hit yet, but then my truck is strickly show and has never been off road or had so much as a spare tire in the box..
hey ford 78, you can run 37's with just the 4 inch lift, without any problems, i have some pics of mine with that setup, if you run a wider tire like a 38.5x16, youll need the 6 inches of lift, more tire than that and youll have to do a little mild trimming on parts of the fender..unless u do a body lift
i got a set of tsl sx's monday 38.5x14.5-16.5 they fit with the 4 inch lift i have to get wider rims i have them on stock 8 inch rim right now once i get the 12 inch rim i can start driving the truck i may have to cut lower front fender but i hope i dont
youl prolly end up having to trim the lower back portion along with the ;lower front part of the front fenders..if u use it off the road where the suspenion sees some movement
