Hi and welcome to FTE, great to have you on board.
500 hp in an F150 sounds like a smokin` truck!
Swing by your local TX chapter and check it out soon: https://www.ford-trucks.com/forums/forum96/
It can break the tires loose @60MPH,I was having fun until the imput shaft broke. I have recently replaced the trans. w/TCI superstreetfighter w/non locking converter. But now it has some ignition problem. The truck just shuts off by itself. The TFI module is getting hot and I`m knocking my head trying to figure this one out.
Try some of the FTE forums such as the Performance and General Engine Building, here`s the link: https://www.ford-trucks.com/forums/forum47/
There are other forums to check out, someone here on FTE will have an answer to your troubles I`m sure.
