glow plug and relay replacement
Old Nov 10, 2008 | 12:34 PM
Iherling's Avatar
Iherling
1995 F 250 7.3 L power stroke diesel. Due to hard starting since the weather has gotten cold, I am going to replace by glow plugs and glow plug relay. Batteries are excellent. A ford truck servicenter told me I should also replace valve cover gaskets and UVC (?) connectors at the same time. Is this true or are they trying to get more work
thanks
Irvin
Old Nov 10, 2008 | 12:42 PM
otpracer100's Avatar
otpracer100
If you are going to replace the glow plugs yourself then just check them when you take the vc off.Check for burnt wires or leaking vc gaskets. Some will tell you how to check the pins in the harness for the glow plugs to see if they are ok. I replaced mine just for peace of mind. If you are having a shop do the work,then inspect the outside of the vc gaskets for leaks before they touch it...just to keep them honest.Just my .02
Old Nov 10, 2008 | 12:49 PM
Iherling's Avatar
Iherling
what are UVC connectors. shop says they have something to do with the VC gaskets?thanks
Neal 97 250's Avatar
Neal 97 250
Don't do the gaskets unless they are bad. They last a very long time.
Old Nov 10, 2008 | 12:50 PM
Neal 97 250
Under Valve Cover connections. Wires run thru the VC and that is where they are they are part of the gasket. Is the shop doing this work?
Old Nov 10, 2008 | 12:59 PM
Iherling's Avatar
Iherling
I am trying to decide whether to tackle it myself or have the shop do it. I planned to do it myself but have not found the time so it is not getting done. Meanwhile it won't start well in the cold
Old Nov 10, 2008 | 01:04 PM
Neal 97 250
If you have the time it is not hard and we can walk you thru all of it very easily. If you can replace spark plugs you can do this.
Old Nov 10, 2008 | 01:11 PM
Iherling's Avatar
Iherling
do you have a good online source for the purchase of valve cover gaskets and UVC connectors, and relay?
Old Nov 10, 2008 | 01:18 PM
Neal 97 250
Not really, Try ftepartsguy or one of our sponsors that deal in stock items.
Old Nov 10, 2008 | 02:12 PM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
F4TZ12A342BA glow plug x8
F7TZ12B533CA relay
check my site for prices.
Ed
Old Nov 11, 2008 | 08:33 PM
GR Miller's Avatar
GR Miller
Looking to change glow plugs myself someone said it was not to hard. It probably isn't after you get to them. I am having trouble finding them are they under the valve covers
Old Nov 12, 2008 | 08:04 AM
Neal 97 250
Yes they are under the VC's. It will take a thin walldeep 10 Mm socket and a ratchet.
There is a small box on the heater box under the insulation. If you remove this small box first it make it alot easir to get the passenger VC off.
Welcome to FTE GR Miller
