Replacing plug or COP too?
Old Nov 9, 2008 | 11:46 PM
ronbo125's Avatar
ronbo125
I have read several great threads on how to replace the spark plugs on a 5.4L and have found the information very helpful. I have two questions I still need help with. Before I ask the question I should explain that the codes are indicating I have a misfire in #6. I have a 2000 expy with 114,000 miles. My questions are:
1. Can I just replace one plug and not the others? I would prefer to limit my work on these plugs as the fewer things I twist the fewer things I can screw up. Additionally, with the economy the way it is I would prefer to save as much money as possible since this thing was running great before this sudden issue cropped up.
2. Does the COP need replaced when the plug is replaced?
3. My friend says that these 5.4L engines are very touchy and can easily strip the threads on the head. Is it as easily screwed up as my friend indicates?
Thanks for all your help.
Old Nov 10, 2008 | 09:45 AM
alloro's Avatar
alloro
1. Depends on how many miles are on the other plugs.
2. The COP could be the source of the skip and not the plug. The easiest way to confirm this is to swap the COP with another cylinder and see if the skip moves with the COP.
3. Your friend is 100% correct.
Old Nov 10, 2008 | 03:18 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
[quote=ronbo125;6747872]I have read several great threads on how to replace the spark plugs on a 5.4L and have found the information very helpful. I have two questions I still need help with. Before I ask the question I should explain that the codes are indicating I have a misfire in #6. I have a 2000 expy with 114,000 miles. My questions are:
1. Can I just replace one plug and not the others? I would prefer to limit my work on these plugs as the fewer things I twist the fewer things I can screw up. Additionally, with the economy the way it is I would prefer to save as much money as possible since this thing was running great before this sudden issue cropped up. Yes you can.
2. Does the COP need replaced when the plug is replaced? No, but it would be a good time to do it, while you have the plugs out.
3. My friend says that these 5.4L engines are very touchy and can easily strip the threads on the head. Is it as easily screwed up as my friend indicates? We have not encountered that yet, but others may have.
Our new Ford COP’s, the Sultans of Spark(S.O.S.), have
been designed with both durability and performance in mind.
Please see them at:
http://www.performancedistributors.com/soscoils.htm
Quality was the main feature we stressed when we went to the
drawing board on these coils.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Nov 10, 2008 | 03:44 PM
ARK Ranger's Avatar
ARK Ranger
cost of the plug change
What would it cost+/- at a ford dealer or a good mech. to change all 8 plugs,cop, and wire on a 2000 5.4 expy.
My truck has 116000 miles on it with original plugs and i can feel it coming soon.
Old Nov 10, 2008 | 06:21 PM
alloro's Avatar
alloro
$700-$900 give or take.
Old Nov 11, 2008 | 11:57 AM
waboose's Avatar
waboose
It probably is your COP misfiring, I would change just the COP and the plug with misfire, then change out all the plugs when your ready. Which at 144,000 miles should be soon, if they have not yet been changed.
Old Nov 11, 2008 | 07:00 PM
ronbo125's Avatar
ronbo125
Thanks to everyone. This information has been very helpful. I'll let ya all know how it turns out when I get some time (hopefully next weekend). By the way, how much does a cop cost?
Old Nov 11, 2008 | 08:25 PM
madsonp's Avatar
madsonp
Here's some for sale on ebay. eBay Motors: 8 IGNITION COIL ON PLUG COP FORD TRUCK 4.6 5.4 6.8 V8 (item 370108302459 end time Nov-12-08 19:05:33 PST)
Old Nov 14, 2008 | 04:04 PM
ronbo125's Avatar
ronbo125
Ok, I changed the plug - man it was nasty looking, rusty.....at any rate I put the COP from number 6 which was misfiring on #5 when I put it back together so that I would know if its a COP problem. Well I'm still getting a code for misfire on #6, but the truck seems to run great.
Do I need to clear the codes and if so how do I do that?
Also, when I picked up the new plug they said it called for a gap of .054. I checked the plug I took out and although I realize it was nasty old and worn, it had a gap of .060. Is this a problem?
Old Nov 14, 2008 | 04:54 PM
vettman80's Avatar
vettman80
Vettman80
A quick way to clear the codes is to unhook the battery for 5 minutes and the reason for a wider gap on the old plug is because it is worn
Old Nov 14, 2008 | 08:41 PM
ronbo125's Avatar
ronbo125
Its fixed
unplugged the battery and it cleared the codes. You guys rock. All is working like a dream. Thanks for your help.
Old Nov 15, 2008 | 10:27 AM
fitzy67's Avatar
fitzy67
plugs and COP
Just change the offending COP for now but buy and extra one to have for the next time. I change all 8 plugs on my 2000 5.4 and it is difficult to get to the back 2 but it is do-able. Just be sure the plugs go in easy and straight. Good luck, fitzy67 2000Exp 193,000 and still strong.
JWA
Apr 16, 2019 08:27 PM
jazztone
Jan 18, 2014 10:38 AM
vze2sgxa
31
May 14, 2009 09:10 PM
vze2sgxa
Modular V8 (4.6L, 5.4L)
20
Aug 8, 2008 06:32 PM
jbennett007
New Member Introductions
Nov 7, 2007 12:58 PM
