Sponsored by: Real Truck
2000 SD Power Door locks
Old Nov 9, 2008 | 09:14 PM
BiggdaddyF250's Avatar
BiggdaddyF250
Is there a way to make the power door locks lock automatically a little after the truck moves? I have power locks and remotes. I tried one of the reprogramming ways I found here, but it does not work.
turn on the key, press the unlock 3 times, turn off the key, press the unlock three times, turn on the key and the horn is supposed to chirp, (mine does not). Then you are supposed to press the lock and unlock and turn off the key, the horn is supposed to chirp twice.
It did not work for me. Is there a way to reprogram it?
Old Nov 9, 2008 | 10:01 PM
pmasley's Avatar
pmasley
First, call your dealer with the serial number to make sure that the truck has this option. If it does, they should be able to tell you how to arm it.
