Sponsored by: Real Truck
Light in speedo
Old Nov 9, 2008 | 06:38 PM
polaris500's Avatar
polaris500
Light in speedo
Ok so i was driving my 06 SD tonight and noticed that part of my speedo is darker than the other half the darker half is from about 65-100 this is gonna drive me crazy as i do alot of night driving with it...
Is there 2 light behind the speedo maybe one burnt out? also how hard is it to change it and how do i go abouts doing it?
Thanks
Old Nov 9, 2008 | 07:28 PM
senix's Avatar
senix
sounds like a burnt out light all right. years past you could take the panel off from under the steer wheel (the access panel) and then with a flashlight you could get up there. Not sure about the newer ones as I have not had any issues,
Old Nov 9, 2008 | 08:21 PM
rudedogii's Avatar
rudedogii
Why are you driving in speedos at night? Ha! Ha!
Old Nov 9, 2008 | 08:40 PM
Hootbro's Avatar
Hootbro
http://www.angelfire.com/tx/hootbro/Cluster_Bulb.pdf
http://www.angelfire.com/tx/hootbro/...er_removal.pdf
Disregard the info of needing to upload the cluster configuration into a diagnostic tool. This is only needed if you are replacing the whole cluster with a new one.
Old Nov 11, 2008 | 09:12 AM
WildWildWest's Avatar
WildWildWest
They are a pain to replace - I have one out in my tach and it annoys me. I think when I pull the cluster to replace the bulb, I'm going to replace them all so that I never have this problem again while I own the truck - hopefully.
