running bad
Old Nov 9, 2008 | 02:45 PM
tims02ford's Avatar
tims02ford
Unhappy running bad
wall its getting 13 mpg and i get a miss at ideal every other week and will go away when i give it gas and you can small the fuel hard core after worm up out of the ext. i have replaced the icp, oil sensor, fuel injet o-rings, i just did a test on the injet and cly 8 came up 3 times but ford is telling me that it will bc has that goofy one on cly 8. the truck is hard to start in the cold but have new glow plugs and is very loud when at ideal and when driving. it will also seem to miss at first start up ever time for a min. let me know i'm going to be out for a few hours please <-- thats what i keep doing with this
Old Nov 10, 2008 | 09:19 AM
Bolt's Avatar
Bolt
Did you clean the EBP sensor and tubes? This was my problem. My fuel mileage is 18.44 now.
Here is what I found and I cleaned out all the sut. This was an easy task.
Old Nov 10, 2008 | 10:10 AM
tims02ford's Avatar
tims02ford
hey bolt cal you call me please so we can talk my #513-673-2274
Old Nov 10, 2008 | 01:17 PM
rbaker6336's Avatar
rbaker6336
did you check the glow plug relay?
Old Nov 10, 2008 | 01:48 PM
just another truck's Avatar
just another truck
Also, your milage may drop now, some fool has decided our diesel needed some additives for the winter. At least they dont charge us more for it, yet..
Old Nov 10, 2008 | 05:54 PM
F350-6's Avatar
F350-6
If Bob didn't get a hold of you, here are instructions on what he's talking about Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old Nov 11, 2008 | 05:30 AM
Bolt's Avatar
Bolt
It will be interesting to see what Tim's problem turns out to be.
Old Nov 11, 2008 | 07:36 AM
Kwikkordead's Avatar
Kwikkordead
Have you checked the compression? A miss at idle, then clearing up if you give it throttle doesn't sound good.
Old Nov 11, 2008 | 07:54 AM
F350-6's Avatar
F350-6
I'm still wondering if he has the 10k mod, and if the problems showed up after the injector o-rings, or is this is the problem he's been chasing. Here's a little more info about his truck taken from a thread in the super duty section.
02 f-250 with
4" bully dog turbo back
AFE stage 2
285/75/16 BFG
ITP BOOST FULLER
OIL CROSS OVER LINE
DP Tuner 60TOW,80ECO,120RAC,140
Gauges Trans,Boost,EGT
Zoodad mod
KC Slim Lights
Fog Light High Beem Kit
Westin Sportsman 1-Piece Grille Guard
ATS Turbo Housing with Wicked Wheel
Foil Delete
Old Nov 11, 2008 | 11:15 AM
tims02ford's Avatar
tims02ford
hey guys i'm trying the evap thing today and no i dont have a 10 k mod
Old Nov 11, 2008 | 08:20 PM
tims02ford's Avatar
tims02ford
well i did the evap cleaning today and it was dirty so i will see in a day or two
Old Nov 18, 2008 | 10:08 PM
tims02ford's Avatar
tims02ford
well it didn't do much at all but i'm going to be ordering new injets
