smoke
Old Nov 9, 2008 | 02:15 PM
7.3mule's Avatar
7.3mule
smoke
do anybody else put out whitesh smoke after idling or when going from a cold start? or how bout when you shut off @ operating temp go in to lowes for ten min and restart; when take off the first couple of times whitesh gray smoke comes out pretty good but eventually go away, also i noticed my oil spout puffing smoke...
Old Nov 9, 2008 | 03:48 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Puffing smoke, or a consistent flow of the oil vapor?
Old Nov 9, 2008 | 04:47 PM
7.3mule's Avatar
7.3mule
puffing smoke
Old Nov 9, 2008 | 05:01 PM
PowerstrokeJunkie
Not good.=Hole in piston, bad rings, o or other wise something that will allow combustion pressure to leak past the piston and into the crank case. Rebuild time!
Old Nov 9, 2008 | 05:12 PM
F350-6's Avatar
F350-6
How strong of a puff? If you put your hand over the oil fill tube to cover the hole, can you feel pressure? If you turn the oil cap upside down on the fill tube, does it blow the cap off, or does it just vibrate off?
Hopefully Kris is wrong, but if you've got pressure coming out of the fill tube, then see above.
Old Nov 9, 2008 | 05:19 PM
jdecker88's Avatar
jdecker88
can you get a video of it puffing?
Old Nov 9, 2008 | 05:36 PM
4inchlovin's Avatar
4inchlovin
White smoke is unburnt fuel... (broken injector, bad piston, bad cylinder wall, bad ring, ect.) Since its "puffing" that would point towards a piston related issue like Kris (strokin_it7.3) said. Go get a FULL compression test done asap...
Old Nov 10, 2008 | 11:06 PM
7.3mule's Avatar
7.3mule
if it was worst case scenario, wouldnt it smoke all the the time? would it also throw a light? truck dosent run like its about to break, it smokes only after idling a while. i will try and get a vid of the smoke coming out of the spout.
johnboytnt
Aug 21, 2012 10:59 AM
URDADDY
Apr 9, 2011 08:16 AM
6.4FX4
6.4L Power Stroke Diesel
Aug 15, 2009 01:48 AM
viperbluelx
59
Aug 29, 2007 05:10 PM
460supercab4x4
Oct 29, 2006 05:39 PM
