Hard starting sorta
Old Nov 9, 2008 | 12:16 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Hard starting sorta
I have a 1997 7.3L with 177k miles, all stock. Here's the deal, when it's cold 35° to 40° I have crank and crank unless it's plugged in.
I have checked the GP relay and it's OK, I am not sure how to test the glow plugs but I'm sure some of them are bad. The heating element in the fuel filter bowl is also broken.
It seems as though it is starting to have problems even when warm. Not real bad but I have to crank it a couple of seconds before it starts. I have also noticed a little lack of power mostly when pulling hills.
SO what do I need to check besides the glow plugs? And how do I test the glow plugs? It's been awhile but if I remember right there are two plugs on each valve cover each with 5 or 6 pins.
Tim
Old Nov 9, 2008 | 03:52 PM
WALJON's Avatar
WALJON
Yeah your right two plugs on each cover 5 pins. Unplug the harness and look in the valve cover part of the connector there is five pins the middle pin is ground the two on either side of it are injectors to ohm injectors put your neg lead on the middle pin and test each pin on either side they should read around 3.5 ohms the next two pins out are the glow plugs ground your meter to the neg on the battery and test the pins they should ohm out at 0.5 or 0.6 ohms.
When you unplug the harnesses have a good look at everything if it smells like burning or there is oil on the plugs chances are you may have melted or burnt wiring under the valve cover
Cuda_jim's Avatar
Cuda_jim
When it starts without the block heater does it stumble and miss a lot?
How does it run when starting with the block heater plugged in?
How did you check the GPR? If you measured 12V on both large terminals when it's
activated doesn't necessarily mean the GPR is good. It may not be carrying the load to the GP's.
There are 2 connectors on each valve cover (VC) that have 5 pins each.
G I C I G
G=Glow plug
I=Injector
C=Common ground for Injectors
Look for burnt pins/sockets in the UVC harness before testing the GP's. It's a common failure.
The GP's should measure 2-3 ohms, anything higher they are getting weak.
There is a harness under the VC's that may need attention too
Old Nov 9, 2008 | 05:05 PM
Tim Young's Avatar
Tim Young
Yes for a few minutes, I can't say that it runs real rough but definitely not as smooth as it should with some white smoke. Last winter when I started having the problem I forgot to plug it in once when the temperatures were in the 20°, I could not get the truck started.
It seems to run just fine but I do have to crank it a few times before it starts.
Well that is the way I checked it, so there is that possibility that it is not carrying the load. It was a while back that I checked it and I can't remember if the truck was warm or not, but if it was cold wouldn't the GPR have a load on it?
G I C I G
G=Glow plug
I=Injector
Old Nov 10, 2008 | 05:47 AM
Cuda_jim's Avatar
Cuda_jim
It sounds like you have 1 or more GP's that are bad. The GPR could be either way. Do the GP's first.
The GPR is difficult to test for load unless you have an Amp meter that can measure very high current.
200+ Amps
If you find 1 bad GP then I would change all 8. It doesn't make sense to me
to change just one GP unless you like removing the valve covers Besides
they are much cheaper now. I get them from ebay for $38 a set delivered
for Motorcraft ZD11 Berus. I wouldn't use any other brand. Autolites and
others can swell and get stuck in the head or snap off...not good!
Here is a link to a GPR mod. It will outlast the truck IMO
2 years is about the longest I've had an OEM style GPR last.
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Old Nov 10, 2008 | 09:48 AM
Tim Young's Avatar
Tim Young
Thanks Cuda Jim,
So the GP's will even make it hard to start when it is warm?
OK well as soon as I get my Bronco out of the shop, I'll put my big truck in there and check it out. I will let you know what I come up with.
Tim
Old Nov 11, 2008 | 06:38 AM
Cuda_jim's Avatar
Cuda_jim
You're welcome.
The GP's will have no effect on warm starting, I don't think you have a warm start problem. You said a couple seconds to fire up....that's about normal IMO.
I think you need to fix the cold start problem first then see what happens from there.
If you do have a warm start problem it would likely be the IPR orings.
