1993 dually bed replacement
Old Nov 9, 2008 | 09:29 AM
On_Final's Avatar
On_Final
I need to replace the bed on my 93 crew cab dually.
I have access to a 1999 short bed, non dually. I would like to use a short bed as I have use for the space between the cab and bed. Will a 99 bed work and if not what will?
Old Nov 9, 2008 | 09:40 PM
gweeds's Avatar
gweeds
Short answer is no, it won't bolt up. That said, you could make it work, but it would require extensive modification of the wheel wells, fuel door, you would have to re-wire the tail lights, drill new holes for the frame mounts, etc...
Your best bet is to just get an 8ft bed that's meant for an 87-96 truck. If you really want to put a tool box (or whatever) between the cab and bed, go to the scrap yard and find a short and long bed, measure the difference between them and see if you think you can make it work.
Old Nov 10, 2008 | 02:25 AM
Waldo1's Avatar
Waldo1
Where are you located? I just bought a 93 ext cab dually for my Dad. He has a work bed to put on it. This means I will have a dually bed for sale.
Old Nov 10, 2008 | 09:34 AM
On_Final's Avatar
On_Final
bed swap
I am in Kingman Arizona. I will be driving to Houston in a couple of weeks. I will find you if the price is right.
Old Nov 11, 2008 | 05:04 AM
Waldo1's Avatar
Waldo1
Talked to my father (his truck) and he wants to wait until the spring when we can get at the utility bed (it is at our cabin in snow country now) and make sure it is going to fit before getting rid of the truck bed. SORRY
Old Dec 18, 2008 | 10:43 AM
db916gt's Avatar
db916gt
I will have a 91 long bed regualar bed shortly if you are interested. i am in the Portland OR area.
