02 sensor replacement- 97 exp
Old Nov 8, 2008 | 05:56 PM
87wreckerman's Avatar
87wreckerman
just picked up a 97 exp, w/ the 4.6, it has a CEL on and the previous owner had the codes scanned and i think it was just 1 o2 sensor in the downstream i think that was bad he said, truck runs fine but he gave me 3 new bosch o2's with it, 2 are part # 15717 & 1 is # 15716 , how many 02's are on the 4.6 total?? i have the special socket also , just wandering how to tell the diff on the part#'s , since 2 are the same want to put the rite 02's in the rite place
Old Nov 8, 2008 | 10:43 PM
alloro's Avatar
alloro
15716 is the upstream one (before the cat.) 15717 is the downstream one (after the cat.) The truck has 2 of each.
Old Nov 9, 2008 | 06:12 AM
87wreckerman
ok thanks, the upstream are the ones that would effect the MPG and all rite?
Old Nov 9, 2008 | 06:16 AM
projectSHO89's Avatar
projectSHO89
Yes.
However, You're probably wasting perfectly good O2 sensors.
There are no conceivable faults that require replacement of all four O2 sensors. Complete waste of money.
I'd suggest getting the fault codes read and starting over before picking up a wrench.
Steve
Old Nov 9, 2008 | 06:19 AM
87wreckerman
rite, he said only 1 was bad from the code he got, but since he gave me 3 i figured mite as well change them while im under there unless there a PITA to change all of them . ill prolly run it up to autozone and have the code read again so i know exactly which one is coming up bad
Old Nov 9, 2008 | 10:14 AM
alloro's Avatar
alloro
3 are easy to change. The upstream passenger side will give you nightmares for several days.
Old Nov 9, 2008 | 11:16 AM
87wreckerman
well its the upstream driver and down stream pass, so far the drivers side is a PITA, any tips on removing this thing?? ive removed the exhaust heat shield and i have the special socket but not much luck on cracking it loose, even sprayed it down with wd40
Old Nov 9, 2008 | 11:37 AM
alloro's Avatar
alloro
Sometimes if you run the engine for a minute and warm the exhaust pipe, the threaded hole will expand enough so the O2 sensor will come out. Just don't let it run too long or it will be too hot to work on.
Old Nov 9, 2008 | 02:30 PM
87wreckerman
got em!! the upstream was a B$#%!!, downstream one came rite out. thanks for the help
Old Nov 9, 2008 | 02:39 PM
Lazy K's Avatar
Lazy K
Good man. Don`t forger to get the codes erased.
Old Nov 9, 2008 | 09:19 PM
87wreckerman
already done, after seeing that pass side uptream 02 i hope it holds out for a while
Old Nov 10, 2008 | 08:23 AM
anfo's Avatar
anfo
Take out the inner fender if you have to change the pass upstream, it takes 10 min and saves hours.
Old Nov 10, 2008 | 08:45 AM
87wreckerman
cool thanks for the tip
