ND I am trying help a friend of mine locate an extension housing bushing for 3 speed borg warner overdrive.He says the part # is B5A7034B.This is all I know!
He says the part # is B5A7034B < < Wrong part number.
The following is the correct part number, it's still available from Ford as it fits many other manual and automatic transmissions:
B3TZ7A034B .. Extension Housing Bushing
(B3TZ-7A034-B replaced B3TZ-7A034-A due to a package quantity change in 1988)
Fits: 1949/72 Warner 3 Speed O/Drive's / 1949/62 & 1963/96 3 Speed Manual's / 1958/67 FX & MX C-O-M's / 1964/82 C4 C-O-M, yadda yadda yadda.
ND,the mechanic realized he had given me the wrong part number when I called him.He said the part number you gave will not work.He needs the bushing for a bigger yolk.He is working on 56 T-Bird with 312 engine!
1.6875" I.D. / 1.7995" O.D. / .870"/.875" long / This bushing was only used on the following > >
1955/56 Thunderbird's with Overdrive.
Green Sales in Cincinnati OH has 16 = 800-543-4959.
Wesley Obsolete Parts in Liberty KY has 5 = 606-787-5293.
Klimesh Motor Sales (Ford Dealer) in Calmar IA has 8 = 563-562-3241
Does this 1956 T-Bird still have its original Overdrive transmission?
There's another bushing that was used on 1957 Thunderbirds & Ford's w/Overdrive.
