TQ spec's
Torque Specifications Description Nm lb-ft lb-in
Vehicles Built Before 12/7/98
A/C compressor mounting bracket to engine 47 35 —
A/C manifold line to compressor 17-23 13-17 —
Crankshaft vibration damper bolt/crankshaft pulley bolt 287 212 —
Cylinder head bolts a — —
Connecting rod nuts a — —
Engine front cover bolts 20 15 —
Engine mount nuts 96-127 71-94 —
Engine rear cover bolts 20 15 —
Exhaust manifold and exhaust adapter pipe nuts and bolts, RHb 24 18 —
Exhaust manifold and exhaust adapter pipe nuts and bolts, LHb 24 18 —
Flywheel mounting bolt
(automatic transmission) 31-53 23-40 —
Flywheel housing cover mounting screws 18-23 14-17 —
Fuel injector hold-down bolts 13.6 — 120
Generator bracket to cylinder head 47 35 —
Generator bracket to cylinder head, lower 40-55 30-41 —
High-pressure oil pump bolts 24 18 —
Camshaft thrust plate to engine retaining bolts 24 18 —
Main bearing cap bolts a — —
Oil level gauge tube adapter nut 33 25 —
Valve cover retaining bolts and nuts 11 8 —
Oil level indicator tube adapter nut 33 25 —
Oil pan to cylinder block 24 18 —
Oil pump screen cover and tube flange screws 24 18 —
Oil supply line to cylinder head fitting 26 20 —
Oil pump housing bolts 14 10 —
Rear oil seal retaining bolts c — —
Rocker arm pedestal attaching bolts 27 20 —
Transmission to engine bolts 52-70 39-52 —
Turbocharger exhaust inlet pipe-to-exhaust manifold bolts 28 21 —
Rocker arm cover bolts 11 — 98
Torque converter to flywheel retaining nuts 30-40 23-30 —
Oil pump retaining bolts 24 18 —
Oil pump screen cover and tube retaining nut 40-64 30-48 —
Camshaft position (CMP) sensor to engine front cover 24 18 —
Access cover bolts 21-32 16-24 —
Vehicles Built After 12/7/98
Access cover bolts 27 20 —
Engine mount bolts 150 111 —
Exhaust manifold and exhaust adapter pipe boltsb 24 18 —
Exhaust manifold and exhaust adapter pipe nutsb 24 18 —
Flywheel mounting bolt (automatic transmission) 31-53 23-40 —
Fuel filter housing bolts 31 23 —
Fuel injector hold-down bolts 14 10 —
Generator bracket to cylinder head, lower 47 35 —
High-pressure oil pump retaining bolts 24 18 —
Lifter retaining plate retaining bolt 20 15 —
Oil cooler front header retaining bolts 24 18 —
Oil cooler rear header retaining bolts 24 18 —
Oil deflector retaining bolts 14 10 —
Oil pump screen cover and tube retaining nut 24 18 —
Piston oil cooling jet retaining bolt 11 — 98
Turbocharger pedestal mounting bolts 24 18 —
Valve cover retaining bolts and nuts 11 — 98
rep ya when i can.. its mix bread...its early99 99.5 01 lol..after today the only thing that will be early 99 is the build date..but i can live with that.....
Some of the specs are lb/in.
Mine is becoming a Hienz 57 as well. 99,99.5 & 02.
