'50 F1 Tailights Brackets
Old Nov 8, 2008 | 07:03 AM
Woodsman_30350's Avatar
Woodsman_30350
When mounting the tailight brackets, does the "U" part of the bracket go up or down?
Old Nov 8, 2008 | 08:27 AM
gdgerland's Avatar
gdgerland
Kent, on mine, the opening of the "U" is up on both sides.
Gil
Old Nov 8, 2008 | 09:03 PM
Julies Cool F1's Avatar
Julies Cool F1
HI again,
I have 53+ shield shape lights on mine but that shouldn't make a difference. Here's a picture (Julie and her pictures!)
Mine is pointing down.
It really doesn't matter actually. If you want the light to be a little higher and don't mind that the bracket arm flows up instead of down, you could put it on the opposite side, upside down, and the light should still be level with the ground. I'm not sure if that would cause any interference with the back of the fender (should actually be better) or the back bumper on the license plate side.
Julie
