Oil Leak
Old Nov 8, 2008 | 01:33 AM
golfnut0001's Avatar
golfnut0001
Oil Leak
Hi there, been a while since I posted, actually had to re-register. Happy to be back.
Have an oil leak which is spraying oil back towards the turbo, firewall etc. Looking at the motor it is near the right rear side. Know thats kinda vague but I can try and post some pics if it might help.
Planning a long trip with a trialer to Florida in late december and am looking for some advice on what it might be.
Thx,
Golfnut
Old Nov 8, 2008 | 06:36 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Post up some pics and let's try and figure it out. I'm betting turbo pedestal o-rings.
Old Nov 8, 2008 | 07:01 AM
F350-6's Avatar
F350-6
Spraying oil from the right side back toward the turbo sounds like the HPO (high pressure oil) line where it attaches to the head. Pictures would be helpful.
Old Nov 8, 2008 | 07:38 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Might be easier to see the exact location of the leak if you clean up the old oil with some kind of gentle degreaser (Simple Green). Then take a couple of pictures of the leak starting up again. Check your oil level.
Good Luck....
Old Nov 8, 2008 | 09:58 AM
Ponyboychris's Avatar
Ponyboychris
Welcome back, I'm with Chris, I think your HPOP lines are your culprit but you need to clean her you and take a look.
Old Nov 8, 2008 | 10:06 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Might also be the EBPV actuator rod in the pedestal... Check around that little gold colored arm that is below the turbo, on the passenger side.
Old Nov 8, 2008 | 10:29 AM
PaysonPSD's Avatar
PaysonPSD
This is what Kris is talking about:
Here's a pic of turbo pedestal with EBPV actuator. Its the rod sticking out on the left. Very difficult to see without a telescoping mirror. Check there for a leak. There may be some grime around that area but if it is wet with oil you have a leak. This pedestal is from an early 99. Another possible leak point could be on top of this pedestal where there are 2 o-rings where the turbo mounts and under this pedestal where there are 2 o-rings where it mounts to block.
You can see in this pic toward the back of valley the 2 o-rings where the pedestal mounts.
Old Nov 8, 2008 | 11:16 AM
golfnut0001
Here are a few pics. When I get a chance to clean it up I will add some more. They aren't the greatest but give an idea. Hope they are of some use.
[/IMG]
Thx for the input so far
Old Nov 8, 2008 | 11:23 AM
golfnut0001
I have a few pics to add but it appears I cannot post attachments.
Old Nov 8, 2008 | 11:59 AM
PaysonPSD's Avatar
PaysonPSD
You need 25 posts to add attachments.
Old Nov 8, 2008 | 12:06 PM
jdecker88's Avatar
jdecker88
Well I think I am going to wait on working on my turbo now.. I am going to do the HPX line seeing how much room is in there now O-o.
Old Nov 8, 2008 | 04:51 PM
golfnut0001
Apparently I can add a thumbnail. I will add more tomorrow.
Old Nov 8, 2008 | 05:00 PM
2000psd's Avatar
2000psd
Hey found my old password. golfnut0001 and 2000psd are one and the same. Will log in under 2000psd from now on.
Old Nov 8, 2008 | 09:03 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by 2000psd
Hey found my old password. and 2000psd are one and the same. Will log in under 2000psd from now on.
I've done the same thing.
I think 2000psd is much more appropriate then golfnut0001.
Now, just like that, you have enough posts to add attachments.
Old Nov 9, 2008 | 02:19 AM
2000psd's Avatar
2000psd
I agree, still can't post attachments tho. DId read that I need to be a supporter to post. Guess thumbs will have to do for now.
Any thoughts from the one pic??
