Wheel bearing ????
Old Nov 7, 2008 | 09:39 PM
heathrunkles's Avatar
heathrunkles
Wheel bearing ????
I am changing the bearings--front end ttb axel. Ford says that there is an inner and outer retaining nut with a washer in between. I don't have this. Just a single nut (in an "L" shape) with a c-clip with a do-hicky thing sticking out. Is this right or did someone forget something?
(sorry for the technical lingo)
Old Nov 7, 2008 | 10:15 PM
RubberDuck's Avatar
RubberDuck
Okay, this is how it should be from the top of my head.
6 allen head screws to take the lockout face off. There should be a spring behind it with the engagement ring.
1 large snap ring, no holes. Just a beveled edge to get a pic under on end. This goes around the entire bearing housing. Just behind where the oring for the lockout face oring seals to the hub.
1 small snap ring on the end of the splined shaft. You can use regular snap ring pliers on this.
**** Now take two allen head screws and screw them back in either side of the lockout body and wiggle the body out.
Next there should be one large lock nut with 4 notches cut out of it for a lock ring socket with 4 nipples. ( I said nipples.....)
Once that's out, there should be a lock ring with holes all the way around it. That comes out with a pick.
Now there should be another lockring with 4 notches with a dowl pin facing the lock ring. This one comes out like the first.
Once that's out, you should be able to wiggle the hub and get the outter bearing to fall out. and the hub and rotor should slide off.
That's it, I'm having a hard time picturing what you are talking about. If you need photos let me know.
Old Nov 7, 2008 | 10:50 PM
ron86toy's Avatar
ron86toy
Yes ....pics please
Old Nov 7, 2008 | 11:03 PM
scatgo's Avatar
scatgo
WHAT?! Pictures of nipples?
Old Nov 7, 2008 | 11:05 PM
heathrunkles
We must be on different axels. Dana 60? I've got the 50 ttb PIMA
Old Nov 7, 2008 | 11:10 PM
ron86toy's Avatar
ron86toy
I call bluff on Cody!!!
He is probably scrambling for his camera praying the neighbors dog is outside laying on her side just to f@#$ with us
Old Nov 7, 2008 | 11:14 PM
ron86toy's Avatar
ron86toy
back on topic...this may help Heath
http://www.motorcraftservice.com/pub...184/E9801B.gif
Old Nov 7, 2008 | 11:19 PM
heathrunkles
How do you post pics?
3 torx to remove cover
large snap ring
small snap ring on shaft
Large 2-3\4 "semi round" nut
done
Thats it and it is in pieces on the floor. I was just checking the torque specs when I saw the two Lock nuts. Inner nut at 50 lbs and back off 1\4 turn -washer-and then the outer at 160 lbs
The one single I took off was tight as crap. Maybe thats why i am changing the bearings now
Old Nov 7, 2008 | 11:21 PM
ron86toy's Avatar
ron86toy
do you have Auto hubs?
Old Nov 7, 2008 | 11:23 PM
scatgo's Avatar
scatgo
Tryed to rep ya for that one.
Old Nov 7, 2008 | 11:25 PM
heathrunkles
yes auto hubs
the link you sent--I don't have #10-13 Just one Big Azz Nut w\ a funky cotter type snap ring
I'vs got a picture on of it but don't know how to post it
Old Nov 7, 2008 | 11:27 PM
ron86toy's Avatar
ron86toy
Originally Posted by heathrunkles
yes auto hubs
that is manual hubs...this is auto
http://www.motorcraftservice.com/pub...69/DE0504A.gif
Old Nov 7, 2008 | 11:32 PM
ron86toy's Avatar
ron86toy
go to this link...on left hit auto hub removal and install
http://www.motorcraftservice.com/ren...e=EN&viewer=IE
heathrunkles
Thats the pic that is throwing me for a loop.
69 66 and 70 are not there
Old Nov 7, 2008 | 11:52 PM
ron86toy's Avatar
ron86toy
Heath,hope that other link helps...there is a link in it for the bearings too.I need to be up in 3.5 hrs......3 hr drive to a pool tournament that starts at 9am.....I will check back tomorrow when I get a chance...I am sure others will chime in if you have more troubles
Thanks...but no need for reps on that one.....it was just a funny
