YFA query
Old Nov 7, 2008 | 09:31 PM
flipklos's Avatar
flipklos
YFA query
Is there a fast idle kickdown on a YFA?
Mine seems to drop idle drasticly about 1 min after letting off the throttle.
I cant seem to find any fast idle speed adj.
Note 300 w 4spd, manual choke (farmboy style).
Old Nov 8, 2008 | 12:38 AM
fmc400's Avatar
fmc400
MSEE
Yes, the YFA has fast idle. Unfortunately the procedure is not so straightforward with these; the adjustment is made by bending a metal rod. Here are some scans of a rebuild sheet, pay particular attention to figures 4 and 9. I didn't see any copyright information on them when I scanned them in so I figure it's OK to post. They're pretty much everything you need to know about setting the choke and fast idle on these carbs. The choke shown in these figures is an auto choke but the fast idle setup is the same.
http://users.ece.utexas.edu/~jlabundy/carter1.jpg
http://users.ece.utexas.edu/~jlabundy/carter2.jpg
Old Nov 13, 2008 | 07:37 PM
ken's 80's Avatar
ken's 80
flip,
I had the same problem with my '80.
I screwed the fast idle screw in quite a bit and it seemed to help. It is my opinion the spring in the auto choke is either too soft or too hard. I'm not sure which, but it seemed the more pressure that was placed on the screw, made it catch on the next lowest step instead of dropping right down to the lowest step.
It took me a while to get it right.
Good Luck
Ken
Old Nov 14, 2008 | 06:22 AM
flipklos's Avatar
flipklos
Got a manual choke. No clue why it dumps idle since, fast idle is controled by manual choke.
tkisling
Jan 14, 2017 01:56 PM
obwan
Feb 16, 2016 07:02 PM
JL-78
Jun 29, 2015 08:58 AM
Jeremy Kamutzki
May 10, 2015 07:45 PM
Demian
Oct 31, 2009 01:49 PM
