Block heater question
Old Nov 9, 2008 | 09:18 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Leaving the ground plug unhooked could be a shocking experience, literally.
If current is leaking to the ground terminal, it is probably leaking to the engine block as well.
Since the truck is setting on rubber tires, the entire truck may be hot when the heater is plugged in.
That would take care of theives, but may not be good for you.
Old Nov 9, 2008 | 12:04 PM
bryansshort's Avatar
bryansshort
Hi, I'm an electrician to trade, not an auto electrician but then this is a mains voltage issue anyway.
!!!UNDER NO CIRCUMSTANCES DISCONNECT THE EARTH!!! it is there to protect you, if you were to disconnect it the entire vehicle would become live!
You have an insulation breakdown somewhere between the plug and the actual heater. The plug and cable are a possibility if they have been badly wired or there is damage but my guess is that the heater element has failed and gone to ground.
The meter you need is an insulation tester not an ohm meter, any decent local domestic electrician should have one and I would make that your first call as they're not cheap to buy.
Where is the block heater to be found, is it easy to access?
Your calculations are all correct regarding wattage and current drawn but you should have almost infinate resistance between any of the conductors and earth/ground. Here in the UK our mains voltage is 240V and our circuits have to be insulation tested at 500v and there must be a resistance between
Old Nov 9, 2008 | 12:11 PM
bryansshort
conductor and earth of at least 1megohm (1,000,000 OHMS) your ohmmeter can not read those values seek an electrician or replace the whole lot element to plug if thats going to work out cheaper.
Bryan
Old Nov 9, 2008 | 02:53 PM
CheaperJeeper's Avatar
CheaperJeeper
OK, well, I think I'll start with removing the cord and seeing if it has a short. If so, I'll replace or repair it. If not, I'll probably bag the whole idea of repairing it - since I have it starting on the glowplugs now, and the block heater is NOT readily accessable (have to remove the starter to replace it)...
Thanks guys, I'll keep you posted on what I find.
Old Nov 9, 2008 | 06:27 PM
Dave Sponaugle
Block heaters are usually around 50 dollars for the 1000 watt version.
Yes changing it is a pain, you always wear some coolant when you pull it out.
But if does make it a lot easier on the starter if temps get very low.
Old Nov 9, 2008 | 08:01 PM
CheaperJeeper
Yeah that is the one thing that makes the constant rain in Seattle bearable - moderate temperatures. It hardly ever gets below feezing for more than a few days at a time here, and hardly ever breaks 95 for more than a few days at a time in the summer...
Old Nov 9, 2008 | 08:30 PM
Dave Sponaugle
Nice heat sink you have to the west for temp moderation.
We have no such temp control here, low to mid 30's for tonight.
Old Nov 9, 2008 | 09:41 PM
jmmartin's Avatar
jmmartin
Hey Dave, should the block heater cord be warm to the touch after about 45-an hour?
Old Nov 9, 2008 | 10:15 PM
Dave Sponaugle
In an ideal world, no it should not be warm.
If you have a 1000 watt block heater you need at least a 12 AWG extension cord if it is 50 feet long.
One of the most common things I see is a cord with conductors way to small powering block heaters.
Old Nov 9, 2008 | 10:23 PM
jmmartin's Avatar
jmmartin
16 awg, 100'. technically big enough, but being an electrician, i do know better. 95' is as close to an outlet as i can get right now.
Old Nov 9, 2008 | 11:05 PM
Dave Sponaugle
But remember, 16 AWG 100 foot long extension cord is actually a 200 foot circuit.
Add to that the lenght from the breaker panel to the outlet you are plugging into and back.
1000/115=8.69 amps at 200 feet is 10 AWG.
And to make it even more complicated, I have seen block heater with wattages from 600 to 1500 at AP stores, yours could be any of them.
Old Nov 10, 2008 | 07:43 AM
gnathv's Avatar
gnathv
If you cut the ground, you may experience the same current on the frame of the truck and this could be deadly.
Old Nov 10, 2008 | 08:43 PM
  #28
Dave Sponaugle
For some reason the block heater end of the cord is molded so it puts a hard bend in the cord, common place for broken conductors.
Check near the fan and belts for cord damage.
Also right at the plug is a common place for cord damage.
Old Nov 10, 2008 | 09:06 PM
  #29
Saleenguy's Avatar
Saleenguy
This will not help your block heater issues.
But the stick on, or magnetic oil pan heaters work great, and also warm the oil making it crank easier.
I had one one my last 3 Ford diesel trucks, and prefer them over a block heater.
And since warmth rises, your heating from the bottom up, where usually the oil stay icy cold.
Old Nov 11, 2008 | 12:29 AM
  #30
LCAM-01XA's Avatar
LCAM-01XA
Saleenguy, where can these heaters be obtained, and how much should I expect to pay for a good one?
