302 tech help (EGR stuff)
Old Nov 7, 2008 | 01:01 PM
93f1505.0L's Avatar
93f1505.0L
So me and a buddy put a 302 in his Nissan pickup. The 302 is out of a 1990 F150 and we converted it to Carb. We used an 4 barrel intake from a 85?? mustang. It has ERG and the hole the is a long oval shape on the top where the Carb bolts down to it. I blocked off the ports in the back of each head too. My problem is that there is a vaccum leak where the carb bolts to the manifold. The carb is an Edelbrock Street Preformer 600 or 650 CFM. It is non EGR. I have a 1 inch spacer on it to get the carb to clear the Truck EFI valve covers. The spacer does not cover the EGR port on the manifold all the way so I made a plate that would and it worked pretty good for a little while but the only gaskets that I could find in town that fit around the ERG didint fit the manifold very good. I kinda made it work for a while with some RTV but it is leaking now.
My questions are:
1. Am I "deleting" the EGR the right way?
2. Anyone know of a spacer and/or gasket that will work for me.
3. Anyone run into this problem before and know what I am talking about?
Thanks
John
Old Nov 7, 2008 | 01:51 PM
Conanski's Avatar
Conanski
I'm no carb specialist but it sounds like you need an EGR spacer.
Old Nov 8, 2008 | 05:08 PM
93f1505.0L's Avatar
93f1505.0L
ok thanks Ill look for one. do you know if this is the only thing needed to do away with the EGR?
