Column question
Old Nov 6, 2008 | 11:16 PM
poorboy53's Avatar
poorboy53
Column question
I am putting together a 51 F1 for a friend.He needs a new column. Will a 55 column work?
Old Nov 7, 2008 | 02:33 PM
Julies Cool F1's Avatar
Julies Cool F1
Hi!
I guess anything is possible but as far as a direct swap, I doubt it.
Length and diameter may be the same. And on these trucks with the way they are mounted that wouldn't make a difference anyway.
The problem you will run into is that the steering box/pitman arm are different as are mounting points.
There's tons of 48-52 columns on e-bay regularly, very reasonable priced. be sure to ask aboutthe condition of the steering box.
J!
