Sponsored by: Auxito
Power mirror problem
Old Nov 6, 2008 | 06:01 PM
magster65's Avatar
magster65
I have an '03 F150 FX4 super. My power mirrors aren't working right. They go down and in but don't want to go out or up very well. This is on both sides. Any one else ever had this or think of what might be the cause?
Old Nov 7, 2008 | 04:32 PM
magster65's Avatar
magster65
anyone there?
Old Nov 7, 2008 | 05:00 PM
KingRanchMan02's Avatar
KingRanchMan02
Sounds like a switch problem. Good luck!
Old Nov 7, 2008 | 07:18 PM
ncranchero's Avatar
ncranchero
Take your switch out and spray it good anywhere you can get fluid to go inside with electrical contact cleaner or WD40, work the button back and forth and blow it out. That fixed mine ........ and it's a cheap try.
Old Nov 7, 2008 | 09:26 PM
coatit's Avatar
coatit
I have the same problem on my 01, how do I get to the switch?
Old Nov 8, 2008 | 11:25 AM
magster65's Avatar
magster65
Yeah, good call. I'll try that today.
Thanks
* coatit - the plastic insert around the inside handle pops off (front first). There's a screw in there to remove then lift the panel up. Be careful of the wires. Have a little screw driver in your hand so you can undo the plug clips.
Old Nov 8, 2008 | 04:06 PM
coatit's Avatar
coatit
I wiil give it a try if it ever stops raining
Old Nov 16, 2008 | 04:50 AM
magster65's Avatar
magster65
It was the switch. I could get it to work intermittantly but not continuously so I got a new one. Swapping that out was about a 1 minute job. How sweet is that!?
Thanks
Old Nov 16, 2008 | 03:44 PM
coatit's Avatar
coatit
I just blew mine out with air and got it to work intermittantly, works good every where but up. sometimes goes up how much is the switch?
Old Nov 16, 2008 | 04:37 PM
ncranchero's Avatar
ncranchero
WD40 it and blow it out again. If that fails buy new.
Direct Ford Parts Genuine Ford Truck Parts Lincoln Mercury Parts OEM Ford Parts and Accessories
Mirror switch, f150 - f150 1997-03, heritage 2004 - F150 1997-03, HERITAGE 2004 97-04 $22.83 $16.21
http://www.FTEPARTSGUY.COM Mirror switch - Regular & super cab - Regular & super cab 97-04 $22.83 $16.44
Front door - Interior trim - Mirror switch
Old Nov 16, 2008 | 06:54 PM
SSG VA BEACH's Avatar
SSG VA BEACH
I have a similar problem, my mirrors will move up and down but wont't come in far enough using the switch. I have manually moved them around. I there a zero point or calibration?
Eric
99 150 4.6 SC FS
Old Nov 16, 2008 | 06:59 PM
ncranchero's Avatar
ncranchero
No, they'll set/adjust themselves.
sdnomad
Jun 21, 2020 06:36 PM
Allenok
May 8, 2012 07:05 AM
sdetweil
30
Jan 8, 2010 10:08 PM
frankyford
Nov 26, 2007 07:16 PM
SPELLY F150
1997 - 2003 F150
Jun 4, 2006 01:25 PM
