I have a 66 4x4 352, with a 2 speed in it. I am not a ford guy, have had all mopars all my life, but I really like this truck. I would like to put a 500 horsepower stroked small block ford in it and have the transfercase rebuilt to handle the power. I need to know what kind of transmissions I could use? Can I use a Ford AOD? Or do I have to stick with a certain model 3 speed? Any Info will help,,thanks guys
2 speed?
What the heck does that mean?
There's no such thing as a 2 speed trans used in any 2WD or 4WD truck.
1966 352 4WD transmissions available.
Ford Type 3.03 all syncromesh 3 speed manual (3 on the tree).
New Process 435 4 speed.
The AOD was a terd of a transmission, wouldn't even hold up to a 302.
The only place I'd stick an AOD, is in the scrap pile.
My truck came with a six cylinder, some body put this combo in.... Is their an automatic 3 speed that will hold up and will bolt up with the transfer case?
250/292 and a powerglide Bill..................a Gasp "Chebby?"
500 horses on a small block.....takes about 10 grand to make that power without juice or a supercharger/turbo. let alone build a transmission to handle it.
Garbz
What 2WD or 4WD Ford truck came with a two-speed Ford-O-Matic?
N-O-N-E = NONE.
What 4WD F100/250 from 1965/66 - 6 or V8, came with an automatic transmission?
N-O-N-E = NONE.
Something smells, and it ain't hay!
If this truck has an FE engine (5 valve cover bolts), 4WD and an auto, it's from a 1973/76 F100/250 4WD, the engine is a 360, the trans is a C6 = 3 speed A/T.
OP, post the VIN from the registration, lets see what this truck was originally.
You know what they used to say Dave = Slip and slide....with Pow-er Glide.
Garbz
I know it takes more $$ to make a ford go fast Ha. I know all about Mopars and making them go fast. We have a 31 Ford model A with a 416 inch small block mopar in it that runs on the street with pump gas. It went 9.66 @ 138, It has about 675 horse. weighs 2700 lbs.
I saw a company that has a 500 horse 427 small block that makes 500 horse carb to oil pan for 7 grand on racingjunk.com I am trying to find out the strongest 3 speed Auto trans I can use with this transfer case.
Are you guys telling me ford never made a 2 speed trans for the v8. The guy I bought this from said it was a 352 with a 2 speed. Maybe third gear does not work?
That is exactly what I'm telling you.
No Ford truck with 2WD or 4WD ever used a two-speed automatic = none.
No Ford truck of this vintage with 4WD came with an automatic of any kind.
3 on the tree, or 4 speed manual only.
Look at the trans pan:
14 trans pan bolt holes = MX Cruise-O-Matic.
17 trans pan bolt holes = C6.
Both of these are 3 speed A/T's, but no Ford truck with 4WD used the MX Cruise-O.
What transfer case do you have? That is the piece of info needed. You can get a C6 for the SBF ( I have one for sale ) then hang a late model T case from a full size bronco or something. The pieces are out there and its only money, hell throw some my way and I'll help you build it.
