GP & GPR System
Old Nov 28, 2008 | 08:15 PM
  #31
T.R.Bauer's Avatar
T.R.Bauer
Here's a question: What does the big relay in front of the GPR do?
Old Nov 29, 2008 | 02:46 PM
  #32
jdecker88's Avatar
jdecker88
That is your air intake heater relay, you can also use it has a GPR if yours goes down.
Old Jan 4, 2009 | 08:57 PM
  #33
pmasley's Avatar
pmasley
Talking
Damn good writeup Jim
Originally Posted by megawatt00
Thanks everyone. Much appreciated.
I did miss the Barometric Pressure Sensor. Thanks Curtis!
This is a new one. Where is this sensor at and will it set a code if it fails? I am still chasing a few demons in mine
Originally Posted by just another truck
I am still waiting
Me too so I can take it to the tire dealership that does not know how to do this.
Old Jan 4, 2009 | 09:05 PM
  #34
F350-6's Avatar
F350-6
The BARO sensor is internal to the PCM Paul. Can't replace it without replacing the PCM. It should set a code, but I'd keep looking at other possibilities if I were you.
Old Jan 4, 2009 | 09:18 PM
  #35
deereman4020's Avatar
deereman4020
Hey I got a question about the GPs and GPR. If my truck heavily smokes pure white about 5-10 min after startup would I have a problem with my GPs or my GPR?
Old Jan 4, 2009 | 09:22 PM
  #36
pmasley's Avatar
pmasley
It could be either. Check the GPR first. If it is ok, then it is time for that dreaded laying across the fender GP check!
Chris, thanks for the answer. I am still chasingthat "No Power" demon and the acting like it is running out of fuel and race cam shake. Once Iget past these three, I believe I will have the demons whipped!
Old Jan 4, 2009 | 09:23 PM
  #37
Steve_250's Avatar
Steve_250
Without more info, I would guess the AIH. Been pretty darn cold up your way. Check the leads/voltage on the GPR lookalike in front of it. If ya need more info, do a search on "white smoke".
Old Jan 4, 2009 | 09:30 PM
  #38
pmasley's Avatar
pmasley
Talking
Steve, I did not pay attention where the poster lives. Good Answer.
Old Jan 4, 2009 | 10:02 PM
  #39
deereman4020
Also on cold nights after school when the temp is about 0*F she starts real hard I have to cycle the GPs 4-7 times.
Old Jan 6, 2009 | 02:48 AM
  #40
pmasley's Avatar
pmasley
That could be any of the three parts of the system. I have narrowed mine down to glow plugs after a 15 degree start the other morning. I forgot the block heater. I cycled the system twice. When it started, the white smoke rolled and it sounded and ran like a hopped up big block. My problem is either glow plugs or the harness. I just cannot get that deep under the hood at the moment to check it.
Old Feb 5, 2009 | 06:16 AM
  #41
just another truck's Avatar
just another truck
A bump to the top!!!!
Old Feb 5, 2009 | 09:39 AM
  #42
superduty4x4's Avatar
superduty4x4
Just unburnt fuel from cold cylinders, should go away as the truck warms up.
Old Aug 6, 2009 | 03:45 PM
  #43
LeeroyDiesel's Avatar
LeeroyDiesel
I've got a P0670 code that i've been chasing and I can't seem to figure it out. Has anyone trouble shot the california GPCM. I put a new one in thinking i did it right and it did not fix the code. The truck seems to run fine but can't get rid of the engine code.
Old Sep 20, 2009 | 10:11 AM
  #44
megawatt00's Avatar
megawatt00
A bump because it is getting close to that time of year.
Old Sep 20, 2009 | 10:44 AM
  #45
schlepprock250's Avatar
schlepprock250
Hey Jim,way to think about people,tried to send reps,but you know...LOL
