Sponsored by: Auxito
loose drivers mirror
Old Nov 5, 2008 | 07:16 PM
murph1's Avatar
murph1
anyone ever remove the outer panel of the side view mirrors?
i have a 99 with power mirrors and the drivers side is a little loose,i'd like to see if i can find out what is causing this..
really hate to damage the paint trying to pry the cover off,when there is an easier way.
Old Nov 5, 2008 | 07:36 PM
ncranchero's Avatar
ncranchero
You have to work through the space between the mirror glass and the housing to release the locking tabs. A small flashlight and long thin screwdriver will do it, with a bit of patience. A little double-sided tape or a couple dabs of silicone sealer will keep it tight.
[IMG][/IMG]
Old Nov 6, 2008 | 02:41 PM
murph1's Avatar
murph1
looks like i found a use for my old long carburater screwdriver..hasn't been used in yrs.
i should have access to everything once the cover is off i'm thinking?
thanks again
Old Nov 6, 2008 | 03:55 PM
ncranchero's Avatar
ncranchero
thanks again
Not much call for those anymore.
1st photo is the inside of the cover, 2nd is the mirror with no cover ........ that's what you'll have ..........
