Carb prob?
Old Nov 5, 2008 | 02:01 PM
kaw200's Avatar
kaw200
Carb prob?
I have a 1985 f250 stick with a 302. Lately I have to choke it(manual choke) to keep it running at idle. Do you think its a carb problem or something like a vacuum leak? I looked for obvious problems and see nothing. Thanks in advance for any help.
Old Nov 5, 2008 | 02:07 PM
Franklin2's Avatar
Franklin2
I would put a kit in the carb. The way the newer fuels they sell attack and gum up the carbs, it would not be money and time wasted.
Old Nov 5, 2008 | 08:08 PM
bashby's Avatar
bashby
its lean for some reason.. Vacuum leak is probable
Old Nov 6, 2008 | 05:58 AM
kaw200's Avatar
kaw200
carb prob
Thanks for the help; I agree it sounds like a vacuum leak, I have gone over the area with propane and cant seem to find anything. I will go over it again.
Thanks.
Old Nov 8, 2008 | 02:53 AM
Opossum's Avatar
Opossum
What kind of carb? A vacuum leak would almost always cause a fast idle, like when you pull out the PCV. Actually try that, pull the PCV out of the valve cover. Does the engine speed up, if so you just need to adjust the throttle idle screw.
