drive shaft Question?
Old Nov 4, 2008 | 09:37 PM
mlcopen69's Avatar
mlcopen69
On my 79 150 4x4 long bed reg. cab 4 speed and a 351 i keep eating up u -joints ( about a set a year) on the rear shaft . but my question is this has a 1 piece drive did they come with that or should it have a D.V. ( double volcity joint)
Old Nov 5, 2008 | 12:16 AM
75F350's Avatar
75F350
You are refering to a double cardan joint, and yes this was available, and could be an option, but you have to determine the angles of the axle, and output shaft first.
You should also make sure that your slip joint is adequate. A dry joint will eat u-joints in a hurry.
Here is a little reading that should get you pointed in the right direction:
http://jniolon.clubfte.com/driveline...nephasing.html
Old Nov 5, 2008 | 12:44 AM
mlcopen69's Avatar
mlcopen69
ok well this truck is stock ( no lift, 9 in rear end) but ill get my hands on a angle gauge and check it out to see if its outta whack
