Sponsored by: Kumho
will this work well???
Old Oct 13, 2002 | 08:07 PM
mooktank's Avatar
mooktank
I have an 89 f150 4x4 5.0 and i am putting on a 6 inch superlift and 3 inch body lift with 36x12.5x15 superswamper tsl radials. Do you think this will work and look okay? also I bought 4.56 gears and I dont know if i should change them or not. I dont know what gears I have in there now but I beleive theyre stock. What do you think of this whole plan?
Old Oct 13, 2002 | 11:10 PM
orange peel's Avatar
orange peel
that should look good, and youll have some flex room for 4wheeling, if thats what your going for. with a 3" body lift you do have to extend your steering linkages and shifters and all of that kinda stuff too. i would go ahead and put in the 4.56's, you will be able to accelerate faster and it will take some stress off the axles but your top end will decrease some.
Old Oct 14, 2002 | 06:36 AM
AZ4x4f150's Avatar
AZ4x4f150
if you're going to install the body lift while you're down there I would suggest changing your body mount bushings from the stock rubber ones to the urethane ones you will be alot happier. When you get a body lift and just install the lift you're stacking new parts on top of old parts. And the urethane bushings will reduce body roll
Old Oct 14, 2002 | 02:55 PM
mooktank's Avatar
mooktank
thanks,
PS - do you think I shoud do the body lift once I have some wider tires? because theyre only 12.5s. Will these rub or would just 14.5's rub? If they wont rub I guess i would wait to do the body lift when I have some wider tires. what do you guys think?
Old Oct 14, 2002 | 04:15 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
i have 33 x 12.5's and a 3" body lift on my f150 and if i turn the wheel the the extreme left and right the tires will rub against the frame. i would extend the wheels out some.
J.R.
90' f150 xlt lariat
300 I6 4x4 5spd
3" body lift and 33 x 12.5" remingtons
3" chrome tube nerf bars
Old Oct 14, 2002 | 06:23 PM
orange peel
my 36's dont rub a bit, but i did hack the fenders up. they only rub under a lot of flex but thats because i didnt hack off enough of the fender.
Old Oct 15, 2002 | 05:05 AM
mooktank's Avatar
mooktank
how wide are your 36's. they make the 36 tsl radials in 12.5 and 14.5.
Old Oct 17, 2002 | 05:40 AM
mooktank's Avatar
mooktank
bump
Old Oct 17, 2002 | 11:44 AM
MustangGT221's Avatar
MustangGT221
They probably don't rub on the frame but I bet they rub on the radius arm.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Thats it for now, saving for a stang. Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Oct 19, 2002 | 06:00 AM
mooktank's Avatar
mooktank
Orange peel, how wide are your tires?
Old Oct 19, 2002 | 10:05 AM
orange peel
[updated:LAST EDITED ON 19-Oct-02 AT 11:06 AM (EST)]12.5", they dont rub on the radius arms either.
Old Oct 25, 2002 | 08:54 PM
mooktank's Avatar
mooktank
what size rims you got?
Old Oct 26, 2002 | 10:05 AM
Yeti's Avatar
Yeti
JOKE-STAR_
Mar 26, 2013 01:02 PM
1978fordf250
Offroad & 4x4
29
Feb 14, 2010 09:13 PM
Shanemh
Jun 13, 2007 03:00 AM
OneSweet81
Aftermarket Products
Aug 15, 2004 07:15 PM
