balancer tick marks
Old Nov 3, 2008 | 08:31 PM
MeanGreen66's Avatar
MeanGreen66
balancer tick marks
Does anyone know what increment the tick marks are on a stock 428FE balancer? The numbers on mine are wore off.
Old Nov 3, 2008 | 09:48 PM
Bear 45/70's Avatar
Bear 45/70
If I can remember correctly, they are 2°, but clean the thing off and you will find that 0°, 10° and possibly 20° and 30° are actually labeled. The damper marks are usually marked from 30° Before TDC to 10° After TDC. FYI, the marks and numbers are stamped into the damper, you can't wear them off. Clean the thing off with some acetone or brake cleaner.
Old Nov 4, 2008 | 06:53 PM
MeanGreen66
I cleaned it off real well before I painted it and the only number that showed up was the 30 BDC, the tick marks, and a vague ADC. I can still see most of the tick marks and I already marked TDC. When I had the heads off I turned the crank until piston 1 was all the way up and when I put the pushrods back on it just so happened that both valves were closed on piston 1. So I am assuming this is TDC.
Also, do you know what kind of advance and spark plug gap I should be running with this engine for max horsepower? I am not worried about gas mileage.
Edelbrock Performer Intake
Crane Cam 290 duration 520 lift
Heddman Headers
10.5:1 compression
bored .030
accel street billet distributor 52200
holley 750 carb
mustang heads
Old Nov 4, 2008 | 06:58 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
yep should be 2* every Mark....and then a long one for every 10*... and the number just to the Left side!!
Old Nov 4, 2008 | 07:01 PM
Bear 45/70's Avatar
Bear 45/70
The ADC on is at 10° ATDC.
Old Nov 4, 2008 | 07:02 PM
RapidRuss's Avatar
RapidRuss
Yep both valves should be closed on TDC!!
