Sponsored by: Kumho
install leveling kit
Old Oct 23, 2002 | 09:53 PM
superrangerman2002's Avatar
superrangerman2002
Old Nov 2, 2002 | 04:55 PM
mustang mike's Avatar
mustang mike
What type of shop would install a front end leveling kit for a 92 f250 4x4,or how hard of a job is it?Every place i have talked to said that they cause alot of problems ,and make it very hard to align the front end?I want to be able to get 315/70/16 tires i have 305's know,and i can't go bigger without lifting the front a little.
Old Nov 2, 2002 | 09:38 PM
Yeti's Avatar
Yeti
[updated:LAST EDITED ON 02-Nov-02 AT 11:20 PM (EST)]Generally a Fabrication shop that deals with automotive repairs should do it, or for that matter any auto shop that knows how to swap out leaf springs can handle it..
Take it to a reputible alignment shop and it should be no problem for them to align, just need the correct degree bushings.
Old Nov 2, 2002 | 10:16 PM
Maxduty's Avatar
Maxduty
This is a fairly straight forward swap that you can do yourself. If your close enough I'll do it. All that is involved is swapping out the leaf springs. The camber bushings are available to correct the alignment and any reputable shop can do it. I usually take mine to the big truck shop for no nonsense business. They should put in the camber bushings, no problem.
