Inside light?
Old Nov 3, 2008 | 08:32 AM
dep295's Avatar
dep295
Inside light?
I have a 89 f150 with a ugle yellow dome light. Im I the only one who hates these lights? I was wondering could it be dirty or do they all look like this? Has anybody ever changed it for another light?
Old Nov 3, 2008 | 09:36 AM
kaug23's Avatar
kaug23
Mine lens was all covered with smoke from the previous owner. I took it off and cleaned it in and out with greased lightning, and it is actually nice and white again.
Old Nov 3, 2008 | 08:47 PM
stanger_missle's Avatar
stanger_missle
What style of dome light do you have?
Mine is the one in the upper left corner. My dad had the same one in his '89. I remember his being not quite bright white, but more of a cream color. I feel that my dome light is dim as well. Taking the cover off will help, but it will look bad. I wish somebody made a crystal clear cover.
Old Nov 3, 2008 | 10:43 PM
atillett's Avatar
atillett
mine broke, and i replaced it with a light out of a ford taurus, which is the newer style light in the 94ish to the 97 model trucks. try the search and type in dome light upgrade...
Old Nov 5, 2008 | 04:41 PM
kaug23's Avatar
kaug23
mine is the standard one in the center of the roof.
Old Nov 5, 2008 | 05:02 PM
212nut's Avatar
212nut
i have the large center light with the two map lights, mine was the same way, i went to auto zone and bought the motormite replacment. it has been brilliant for about 6 or 7 years now.
212nut
1992 f-150 4x4 flareside
1984 mustang gt-350
1967 f-250 4x4 highboy
Old Nov 5, 2008 | 07:19 PM
stanger_missle
Whoops, I broke my own link LOL. Thats what I get for doing some house cleaning on Photobucket.
Pic fixed!
Old Nov 6, 2008 | 04:29 PM
dep295's Avatar
dep295
Mine has the center light with the map lights on the ends. I have taken the lense of and tried to clean it but with no luck.
Old Nov 7, 2008 | 05:12 AM
TexasGuy001's Avatar
TexasGuy001
I can't believe they used that old dim 80s style light in our trucks. I changed mine to the a newer style light out a the rear of a superduty crew cab. The regular cab makes the light angle up slightly. The lense for the map lights is different and helps angle the beam down. If you have an extended cab then it doesn't matter and the regular newer dome light will work just fine. The lense is the only different part, the rest of the light is the same. I think they started using the newer light in 96 but it was black. The one I found is gray. I think NPD or LMC sells new ones. You can get one on ebay for about 20 bucks.
I know the gray is slightly off, but the camera flash makes it look worse. In the regular light it looks perfect.
Old Nov 10, 2008 | 12:21 AM
scab's Avatar
scab
I have a 94 F250 extra cab and used a dome light from a 2004 mustang and a rear view mirror with map lights out of a newer Chevy Lumina dome light fit in original holes. Cost $7.00 plus $2.00 to get into the junk yard.
Old Nov 10, 2008 | 10:44 AM
RiverRat1964's Avatar
RiverRat1964
I'm switching all mine to LED's when I get the chance, brighter and longer lasting.....
Old Nov 10, 2008 | 11:44 AM
TexasGuy001
I considered replacing all the bulbs with LEDs but that would be expensive since they cost more than twice as much as the regular bulbs.
