Need Help please
Old Nov 3, 2008 | 03:17 AM
aknative84's Avatar
aknative84
Exclamation Need Help please
Hello i have a 1986 Ford F150 and i was hoping to pick a few brains out there because mine can't seem to figure out something with my truck. ok i'll start this off, when i was driving it just quit........... ok now i know first to ask is is there spark? yes my fingers were tingling for about 2 hours after the pumps don't have power the injectors do not have any power the relay that i found seems to be good its the one when you pop the hood it's there on the drivers side firewall. none of my books say what that one is for but i bough a new one and nothin. she will start on the spray kinda, if i take the air intake line off and put gas right down her throt shell start. other than that it won't run long and just stop again.... help please.
Old Nov 3, 2008 | 05:17 AM
ri_truck_guy's Avatar
ri_truck_guy
It sounds like you have a 302. Have you tried pulling engine codes yet? That should always your first step when diagnosing an EFI engine.
Old Nov 3, 2008 | 07:41 AM
uncle.stosh's Avatar
uncle.stosh
That and break your posts into legible sections so we can read it.
Old Nov 4, 2008 | 11:14 PM
tommy70084's Avatar
tommy70084
hello if u put fuel in that line and it will run for a sec try the fuel pump first check the power going to it check to see if u have on on the fram and one in the pump most of the time the one on the fram is the bad one i dont know but check to see if u has a fuel shut off switch in the kick panel with the red button on top try to push check fuel filter the relay under hood do u have a green and a brown one the green one should be for fuel pump if u have two tanks try to switch them i hope this helps
mister_eicher
Nov 10, 2014 05:14 PM
kmrod
Mar 15, 2013 03:33 PM
BayouBoy827
1997 - 2003 F150
Aug 4, 2011 11:16 PM
Grandmaster B
28
Aug 31, 2007 10:57 AM
joelaurenson
1983 - 2012 Ranger & B-Series
Feb 7, 2005 03:32 PM
